The Daily Firewood Picture Thread
Started by mike_belben, May 09, 2021, 11:23:57 PM
mudfarmer
My stove has a pretty hard 16" cutoff or things get ugly, and other people also expect consistency but I am still bucking by hand (no processor) So I do it like Hilltop but for every block. Attaching things to the saw, marking separately, using a stick, eyeballing, none have worked out great for me whether too slow or cumbersome or bad eyeballing  ffcheesy
Been cleaning up dump truck loads of butts, shorts and offcuts that are in the way. Would like to fire the driver that just dumped them everywhere but then I would be out of work.
Hilltop366
I have only cut for myself and the boiler and splitter will go up to 24" so I do have a bit of lead way.
It probably would be different cutting to sell.
mudfarmer
Mr. Fred Fakename had three or four pieces that were longer than the rest out of a cord and he made sure I knew it  ffcheesy
I have bucked many different lengths and can gauge the lengths well enough, but it is just so nice when they are all the same.  When we used an open fireplace I bucked @26"-28".  With a ledger stick I can fudge one way or the other with limb forks before I ever get there so that there are never any surprises.
My fireplace insert door opening is 19" so I mark @ 17".  I can easily handle anything from 14" to 20".
doc henderson
My stove will take over 24 inches sideways, or 16 inches front to back.  It looks nice stacked on the rack on the back porch if they are somewhat uniform.  If the fire is raging the 16 inches front to back is easier to get in without a jam that holds the door open or get hot on the hands.
NE Woodburner
Quote from: Magicman on June 11, 2024, 12:56:51 PMInverted tip marking paint that is made for marking underground utilities.
This is what the Mingo marker uses. There are different size wheels to mark the length you want. A ramp on the wheel triggers a spot of paint every time it comes around. I cut mine at 18", but I have wheels for other sizes. You can mark a whole log very quickly.
I am not familiar with the Mingo, but I have a trigger pull "wand" that a can snaps into which is used for marking buried utilities without bending over.
Funny but my Florescent Green is the color used for marking sewer lines.  :wacky:
doc henderson
Hilltop366
It all looks the same length when it comes out of the stove. ffcheesy
NE Woodburner
Quote from: Hilltop366 on June 12, 2024, 04:50:03 PMIt all looks the same length when it comes out of the stove.
Similar to what Dad used to tell me when I complained about handling crooked firewood limbs as a kid - "it all makes straight ash".
We did everything by hand, so I much preferred splitting nice, straight grained oak or ash logs. He used to take every limb down to almost pencil sized. I drop trees and cut tops and pull the logs and large limbs out with my tractor and winch. I leave a lot of small stuff in the woods now and I often think about what Dad would have to say about that.
This may not seem like too much for you less than 80 youngsters, but I was ready for a break after bucking these limbs.
I went through 3 tanks of chainsaw gas getting it done.  Now I gotta load the tractor bucket and haul it to the woodpile for splitting.
Another advantage of using a ledger stick.  Just stick it through the debris, mark, and then trim it all off when I come back bucking.
doc henderson
this is nice if a few folks are bucking.  I agree that after you have rounds laying on the ground, you can eyeball them.  also, you may fudge one-way or another with limbs and knots. ffsmiley
Well, I did done it:
The last bucket load of rounds about ready to go to the wood pile.  My Hand Tongs and Logrite Hookaroon "gathering tools" sneaked into the picture.
Heck-of-a-whack of rounds ready to be split and/or wheel barrowed to the firewood shed.  Lotsa work for da old man.  :uhoh:
Weather permitting, I will be sawing Monday.
B.C.C. Lapp
mudfarmer try one of these.  Get em BOTH.  Green and red. On bright sunny days ya can't hardly see the red, but the green one only lasts half as long on the battery.
I was skeptical but I use these and my cuts are all within a half inch of 16inchs now.
https://westcoastsaw.com/products/firewood-prosizer?variant=43321892733158&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=Cj0KCQjw4MSzBhC8ARIsAPFOuyVXTH__2bIwW6BqUoXm_6CXkxQ_imKJzWCujKNaHoEpLuI1HhkG63oaAs3-EALw_wcB
Listen, or your tongue will make you deaf.
jimbarry
Recent goings on in the wood yard, over the previous 30 days.
https://www.youtube.com/watch?v=DsRkf7HDlTw
mudfarmer
Hey thanks BCC that's pretty neat  :thumbsup:
cutterboy
Jim, that was fun. Thanks.
To underestimate old men and old machines is the folly of youth. Frank C.
woodroe
Sometimes its easier and saves a step to buck and split the wood where you find it. Especially when its smaller wood all in a tangle within 30' . Leaves the mess in the woods too, falling off bark in this case being mostly dead blowdowns.
Skidding firewood with a kubota L3300.
