Go Big or Go Home, Going Big
Started by SawyerTed, May 28, 2021, 12:10:28 PM
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
moodnacreek
This is all interesting to me as it represents the opposite of what my little 1 1/2 man sawmill does and the way I think. I try to fulfill a small special market that can make a profit  and therefore ignore the low grade as much as possible. It has to be this way because production is so small.    So you are taking hardwood pulp or other small dia. wood and producing what it is good for in bulk. I suppose volume is a must.   Anyhow timing is everything and fuel just went berserk so if this keeps up the firewood will sell and must cost more also.   Seriously the best of luck with all this, Doug
jasonb
It is not every day you get to see a paper chart recorder in use.  Is it for regulatory purposes?
HM122
SawyerTed
Yes for corroborating the boiler and kiln runs.  Boiler has to be at operating temperature and pressure at the same time the kiln is meeting USDA heat treatment temperatures.
We intend on running heat treating charges for dunnage and pallets.  The  documentation will be there for QA.
