Author Topic: Decided to go gas. 8.1 to be exact. 04 model  (Read 2761 times)
Offline Tacotodd
  • To learn and help
Re: need a higher output motor for my 01 Chevy 6.0
« Reply #20 on: June 06, 2021, 05:28:40 PM »
Educate me, whatís a Smoot?
Trying harder everyday.
Offline btulloh
« Reply #21 on: June 06, 2021, 05:37:01 PM »
I lost confidence in the smoot when it was recalibrated about five years ago. Since then Iím always uncertain which version of the tape I was using. To me, the recalibration made the smoot moot.
HM126
Offline barbender
« Reply #22 on: June 06, 2021, 07:34:49 PM »
Southside, once again I am left questioning your "moderating" influence😂
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #23 on: June 06, 2021, 08:04:07 PM »
5'7".
12 valve swap. Tune it for 350 hp/900 ft/lbs and never look back. :)
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #24 on: June 06, 2021, 09:07:14 PM »
Sorry to hear about your health challenges
You can build a 6.0 to make that HP but you may not like it for your application,
6.2 would work as @btulloh noted
or
Chevrolet Performance ZZ502/502 Deluxe 502ci Engine 508 HP @ 5200 RPM
your looking at $10 K drop-in with mods
D
Offline chevytaHOE5674
« Reply #25 on: June 06, 2021, 09:26:47 PM »
You surely can build up a 4L80E. With deep enough pockets can build it to hold 1200hp.
As for a stocker holding 450hp I would say you better be gentle on it and have a temp gauge and keep an eye on things like a hawk. If towing in the summer add a 2nd cooler and say a prayer. A stock 6.0L will eat up a 4L80E if too much torque management is removed from the ECM.
If I was planning on putting 450+ hp thru a 4L80E that is 20 years old with 275k miles I would have a good shop go thru it and put a good convertor in it, as well as a good set of frictions and steels. There are some upgrades that should be done to the valve body as well.
Offline Patrick NC
  • I'm not new anymore, but still pretty green
« Reply #26 on: June 06, 2021, 09:50:02 PM »
I don't have any experience with the 4l80e but I had a 2014 Silverado 2500 6.0 with a 6 speed automatic. This was my work truck before I got the Duramax. Pulled a ctl on a 7 ton deckover at least twice a week. Replaced the first transmission at 105,000 and the second one at 175,000. Both were done at the dealership. Transfer case at 125,000 and rear end at 150,000. We had 2 other 6.0s on the fleet that all had similar issues. No problem with the engine, just the rest of the components not quite up to pulling heavy loads frequently.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
« Reply #27 on: June 06, 2021, 10:09:47 PM »
If the fluid is kept up the transfer case and rear end should hold up no problem. The transfer cases did have a habit of the pump chewing thru the housing though.
Offline Southside
    • White Oak Meadows
« Reply #28 on: June 06, 2021, 10:33:10 PM »
@btulloh
The re-calibration, due to annual third rock solar ellipse completions, of the Smoot isn't necessary if you utilize the original basis for determination.  Namely one Smoot = 1/364.4 HB, where HB stands for Harvard Bridge.  The basis value has not been impacted by the annual trips nearly as much as the subject originator.  Granted using such a precise basis value has it's complications when determining distance in Smoots, especially in areas distant from the original subject, but calibrating a log tape in Smoots using the original basis should be pretty easy for a modern manufacturer determined to build precision measuring equipment, such as say Starrett given their proximity to the originator.  - Just saying.
@barbender I don't think anyone has ever accused me of being "moderate".   :D
As far as Newton-Meters goes, I had to convert that to Ft-Lbs and degrees one time when doing a head gasket job on my Kobelco excavator that has an industrial Mitsubishi engine in it and torque to yield head bolts.  My torque wrench was like --- Whaatt?
White Oak Meadows
Online mike_belben
  • Pulp Friction
« Reply #29 on: June 06, 2021, 10:39:50 PM »
youve got good taste dave.
mine made 290/630 just on air filter, injectors and some pump tuning at stock timing.  and it was plenty to pull 25k gross as fast as you wanted.  but the 3500 didnt have enough brakes or leafs to feel good.  and that was with ford F350 twin piston calipers.  2nd gen dodge can use all the parts off a balljoint ford d60 from the knuckles out so i did a swap to get the better brakes and twisty hubs.  i do sorely miss the truck.  for pulling just a skid steer it would braaahhp up any hill in new hampshire for sure.  a spit pushrod is the only real issue it ever gave me.  hammered it flattish on a curb stone, lashed it and got back on the road. its still in there.
my international 1600 has a pretty built 466 and a double over 13spd and that feels rock solid up to 40k in the mountains.  probably makes 300/800.  much better toter than the dually once you break the 20k mark.
Isaiah 63:10
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« Reply #30 on: June 07, 2021, 01:03:19 AM »
Done a while back
Offline farmfromkansas
« Reply #31 on: June 07, 2021, 10:39:44 PM »
Why not just buy a one ton truck dually with a 454 if you like GM?  I have a F450, with V-10, great motor if it will just run.  My fuel pump is acting up, hope that is all that is wrong.
Offline Sedgehammer
« Reply #32 on: June 08, 2021, 02:05:02 AM »
If'n one was avail w/ a crew, auto and wearing leather, I wood most seriously consider. I owned one of the 1st crew shorty 4x ever made. I can't find squat
Offline Sedgehammer
Re: Decided to go older diesel. 6.0 PS vs Duramax vs 7.3 PS
« Reply #33 on: June 08, 2021, 01:33:08 PM »
I know the 6.0 power strokes have head issues. I'm talking about those that have been refitted w/ studs. They don't need to be 'bullet proofed, as that's a name brand
Have an 06 getting new injectors being installed. It's also been deleted. Florida truck. No gooseneck ball. 220k miles. $15k
Also looking at a 05 duramax. Gooseneck ball.198k miles. $15.9k
A 02 PS. 300k miles.  No gooseneck. $10k
All nice trucks. All crew cab and automatics
Offline Southside
    • White Oak Meadows
« Reply #34 on: June 08, 2021, 02:28:31 PM »
The '05 Dmax is an LLY, they have a tendency to overheat when under a significant load.  I would try to find an '06 or '07 LBZ if you go GM.  That is the cats meow.  The early '06 had a crimped head gasket and they all fail eventually.  The upgraded riveted gasket has proven itself.  You can tell looking at the engine if the gasket has been done as there is one corner of the head where the gasket sticks out and the two designs are easy to distinguish.
White Oak Meadows
Offline Sedgehammer
« Reply #35 on: June 08, 2021, 02:34:40 PM »
you are correct on the over heating issue. Wood replace current radiator and fluid first things if purchased
cannot find any in that year range in the price range (under 16kish). what they want for those years, might as well keep my 16
Offline Southside
    • White Oak Meadows
« Reply #36 on: June 08, 2021, 02:40:11 PM »
It's not the radiator - rather it's internal passage flow.  Not saying it's a bad engine, but if it's going to work for a living, then it's going to give you issues.
White Oak Meadows
Offline Bruno of NH
« Reply #37 on: June 08, 2021, 03:41:51 PM »
I can't remember what year it was. I bought a new Chevy one ton gas with an Allison trans and big gas engine .
8. Some thing.
That thing was a beast pulling but I had one back of a gas bill at the end of the month. I pulled my 24' job trailer full of stuff all over NH and Vt.
I traded it in for an awd 2500 van and parked the trailer.
Cut my gas bill in half.
The van had a 5.3 and was chipped.
I did miss that Allison trans.
Offline firefighter ontheside
  • I like trees.
« Reply #38 on: June 08, 2021, 03:53:06 PM »
What has been done with that 7.3?  Of course they can go a long way, but I think at 300,000 miles it will have already had a bunch of work or it will need it soon.  The B&W turn over ball hitch is easy to install in the 02.  I don't remember exactly but I think it was around 300 for just the turnover ball.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline snowstorm
« Reply #39 on: June 08, 2021, 04:36:49 PM »
The prices seen high to me maybe itís the market where you are. I sold a 02 for 3500 last summer. It did need a oil pan but ran like a top. Three yrs ago I bought a f350 plain xl 6.7 80000 miles from a Ford dealer for 17 k.I had a 250 6.0 and still have a f550 6.0 that has plowed roads since it was new. The only big repairs were. Fuel pump. Turbo. The actuator stuck. And last winter when scanned it showed low high pressure oil. It turned out to be the wiring plug on the ipr . An 06 is the last full year. 07 was a short run only a couple months. But the 6.0 lived several more years in the e series van. That would have the 5 speed auto. Not a bad trans better than the 4 l80 of the 7.3 days itís not the pretty much bump proff .6 sp you get with the 6.7. A guy I know stopped in Sunday to show me his new truck. In 18 I bought a new 250 6.7 lariat ultimate. Now his is a 19 50000 miles just like mine he paid 68 k thatís more than I paid for mine and it was new
