Author Topic: Decided to go gas. 8.1 to be exact. 04 model  (Read 2846 times)
Offline Bruno of NH
Re: Decided to go gas. 8.1 to be exact. 04 model
« Reply #60 on: June 16, 2021, 05:50:44 AM »
Like I said
I had a 8.1 it was a beast and pulled hard.
The new ford gas 7.3 is getting factory twin turbos next year.
Offline snobdds
« Reply #61 on: June 16, 2021, 10:35:58 AM »
A twin turbo 7.3 from the factory. OMG, take my money.
This might be the only way I get out of the diesel for heavy hauling.
Offline Skip
  • Saw hard or stay home.
« Reply #62 on: June 16, 2021, 03:07:27 PM »
I ordered a 21, 2-3 months go. Dealership said it has been converted to a 22  ::) ,said I might get it by fall . I ordered the 7.3 gasser if it comes with twins, it just might be worth the wait  ;D .
Offline Bruno of NH
« Reply #63 on: June 17, 2021, 07:27:28 AM »
If I won the lottery
I would get a f250 2wd with 7.3 twin turbos lower it , cat backs, chip it and 60's all around.
And do some smoke shows around town  :D :D
Offline reride82
« Reply #64 on: June 17, 2021, 02:56:31 PM »
Does it have an Allison transmission behind it? My dad has an 04 with 55-60K miles on it I believe. It pulls like a freight train, but mileage was terrible thus the low miles. Now he has a 6.7 Powerstroke so it mostly sits. He won't sell it, which is aggravating :D
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline Bruno of NH
« Reply #65 on: June 17, 2021, 05:41:16 PM »
I had an Allison in mine it pulled hard .
5 to 6 miles a gallon at most.
Online HemlockKing
« Reply #66 on: June 19, 2021, 12:28:38 PM »
The “brodozer” lol
“A society that puts equality before freedom will get neither. A society that puts freedom before equality will get a high degree of both.“
Milton Friedman
Offline mike_belben
  • Pulp Friction
« Reply #67 on: June 21, 2021, 08:53:21 AM »
That is pitiful.  Old semis fully loaded get that in the mountains. Theres no excuse for a pickup to be that bad.
My 12v dually got 11 with a bad convertor!
Isaiah 63:10
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« Reply #68 on: July 02, 2021, 12:41:39 PM »
Has Allison
12 mpg empty
7-8 mpg loaded
The 16 duramax gets 9.5 loaded with same load
I'll take the gasser. Small fuel tank. That sucks
On the 7.3 gas from ford w/ twins. No need for it to have twins. The extremely small advant isn't worth the extra costs in my opine. A motor that small and with that low of boost psi, nope
Offline barbender
« Reply #69 on: July 02, 2021, 02:12:09 PM »
I wouldn't be surprused if the twin turbo setup has more to do with emissions than power.
Offline Bruno of NH
« Reply #70 on: July 02, 2021, 05:04:47 PM »
I was jobing around a lot when I had that truck.
24' job trailer on the back pulling lots of hills in NH and Vt
Offline Sedgehammer
« Reply #71 on: July 02, 2021, 05:09:01 PM »
Yeah maybe, but hard to see where 2 help in any noticeable way, but they wood know that if that was the case
Offline Sedgehammer
« Reply #72 on: July 02, 2021, 05:11:14 PM »
and how much better does a diesel get pulling same load. Like I said earlier, we get about 2 mpg lower pulling same load. If that holds or anywhere near that, again proves that the diesel isn't worth the extra costs
Offline chevytaHOE5674
« Reply #73 on: July 02, 2021, 07:04:00 PM »
When you say loaded what does that mean? 20k lbs? 5k lbs?
Your loaded diesel mpg seems low. Guy hauls a lot of hay for me with 21k lbs of bales on a 9?k lbs trailer and averages 13.5.
I hauled almost 17k lbs of pipe and trailer behind my old 7.3 2 weeks ago and averaged 16.3 over a 250 mile trip.
Offline Sedgehammer
« Reply #74 on: July 02, 2021, 11:05:17 PM »
14k
The diesel doesn't even know its back there. Amazing power. On the mileage. I didn't manually check it. I was going by the computer. The gas we manually checked
I guess it could be off, but doubt that much
Offline Sedgehammer
« Reply #75 on: July 03, 2021, 11:43:55 AM »
I am going to put a set of stainless headers, that'll help a bit also
I do see they make a blower setup for it. $7,100. Not too bad. It does take new pistons though if you want over 5 psi. I'll maybe do that next year
Offline Bruno of NH
« Reply #76 on: July 03, 2021, 12:19:00 PM »
The diesel engines aren't worth the extra for me.
I know most won't agree with me.
If I was pulling load cross country I would consider it.
Offline barbender
« Reply #77 on: July 03, 2021, 02:09:44 PM »
The mileage computers are about as accurate as the weatherman, in my experience
Cat ACERT diesel engines run twin turbos and it has something to do with emissions.
Offline Sedgehammer
« Reply #78 on: September 12, 2021, 09:13:03 AM »
Just got back from Georgia with this load. 11 mpg w/ trailer empty average and 8 loaded. Total load was just under 18k. Set cruise at 75 and it barely wavered no matter the hill
Did add a 50 gallon transfer tank though. Could save $0.20 per gallon on a fill up by using the gas app
Offline farmfromkansas
« Reply #79 on: September 12, 2021, 11:15:11 PM »
My old F-450 with the v-10 averages about 12 empty, but I can't go as fast with the 488 rear gear.  Just don't want to scream the engine.  Pulling the trailer in 5th gear, I run about 55. It is the 6 speed manual, 6th is OD.
