Author Topic: Does anyone have a trailer for sale that has been modified for loading logs?  (Read 1214 times)
Offline burdman_22
I'm interested in a trailer that has been modified for loading logs if anyone has anything like that for sale. Maybe like a log loading arch thingy? I'm tired of dragging logs up onto trailers with a winch...haha. (also I dont even have my own trailer yet, so would be nice to buy one already customized to suit my needs)
I have read, understand, and agree to the terms of posting an ad on the Forestry Forum.
Offline jmouton
  • never enough time
    • Log-Gistics
how heavy duty of a trailer you want,,,i have about 4 trailers in various states of rebuilding
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Offline burdman_22
I'd like a double axle at least 14 ft long. Would love some capable of handling 3 ft diameter logs
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Should be looking for a trailer rated at least 14,000 lbs. GVWR.  Double axle trailers usually start with ratings of 7k, go to 10k, 14k, etc..  A 36"x13' oak log will go about 7500 pounds, probably over the payload rating for a 10k trailer.  GVWR includes the weight of the trailer and, if a log lifting arch has been added, along with a couple of tail trailer jacks and a winch/battery, that all reduces your allowable payload.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Offline burdman_22
I drive a 2008 Silverado 1500, so I dont need anything too monstrous. For my truck standard towing is listed as 7300 pounds. It will be rare for me to be hauling anything 3 ft in diameter....normally anything over 3 ft wide I just mill myself with my chainsaw.
I'd say a 10k trailer would be all I'd need, else I risk having so much trailer it maxes out my towing capacity before I have anything loaded, haha.
Offline tacks Y
I have a little trailer 10' (not selling) but I made so fender removes. I would roll logs over the side not the best but it works. Now that I am older I use a wheel loader and dump truck or bigger trailer.
Offline fluidpowerpro
  • Hi there!
Check out a guy named Matt Cremona. You can find him on the web. He recently built a nice arch type trailer that he hauls some really big logs with. You could probably start with a standard trailer and add the arch yourself if your so inclined.
Change is hard....
Offline burdman_22
Yeah I've seen Matt Cremona's. That is what I want, but I dont have the time to build anything like that. I've contacted some fabrication shops in my area but havent been able to get anyone to even give me a quote on something like that :/
Online Iwawoodwork
Usually the axles with 5 lug bolts are a 3500# axle and the 6 lug axles about 5000# each. A flat deck trailer with the bed above/over the tires will be easier for side loading/unloading logs/lumber.  If you want to end load from the back then the fenders are not such and issue but can end up with a less versatile trailer because the fenders/tires get in the way. I have both types.
Offline ajsawyer
This is what you need: https://youtu.be/Ckh6VHfzP_0
Offline burdman_22
@ajsawyer Actually this wouldn't be good for me at all. I want something I can haul multiple logs with, and something that will work as a normal trailer too (I have to have a trailer to haul my chainsaw around on).
Offline Daburner87
  • Dusty
In this vid he loads multiple logs...
Pretty *DanG cool trailer, but I understand what you are saying about having normal trailer use and not just a specialty log trailer.  A flat deck trailer with side rails and a winch seems like the best option for you.
Soon to be  owner of a HM130Max Woodlander XL
question about loading logs onto the trailer
Started by Robert R on Forestry and Logging
Last post March 14, 2005, 08:53:20 PM
by Furby
Poulin 17' 30,000 LBS. Forestry Trailer Self-Loading Log Trailer
Started by 2StateTrigger on For Sale
Last post June 28, 2019, 05:48:10 PM
by 2StateTrigger
Loading a trailer
Started by Raider Bill on General Board
Last post August 08, 2008, 07:28:43 PM
by maple flats
Log trailer loading arm?
Started by mart on Sawmills and Milling
Last post March 23, 2019, 08:12:10 PM
by Pepe_Silvia
