Author Topic: Storing and drying in shed  (Read 340 times)
Offline Tinkerer
  • I need a chainsawaholics anonymous meeting
« on: July 24, 2021, 08:51:45 PM »
Anyone stored and dried lumber in a wooden shed? Im planning on filling about 1/2 of a 10x14 wooden shed with fresh lumber. It has 2 windows and 2 gable vents. It will keep our yard tidy and I can theoretically use it as a kiln. No power to it (yet) but its in the works. My only concern at this time besides weight is possible lack of air flow. I can add fans if anyone thinks that will be an issue. Im in Maryland. Wouldnt take too much additional heat in the summer to get the interior to 130F
Fed my 450 Rancher so well, it grew to a 395XP!
Offline moodnacreek
  • Sawin by the notches
Re: Storing and drying in shed
« Reply #1 on: July 24, 2021, 09:51:58 PM »
Air flow is more important to green lumber than heat. If fresh cut pine it will blue stain and worse.
Offline Southside
    • White Oak Meadows
« Reply #2 on: July 24, 2021, 10:01:18 PM »
If you fill that with pine it will stain, mold, and grow nasty fuzz.  If you fill it with oak it will split, twist, warp and do everything else you don't want it to do.
Too hot and not enough air for green wood.
White Oak Meadows
Offline firefighter ontheside
  • I like trees.
« Reply #3 on: July 25, 2021, 10:03:24 PM »
I think you'd be better off doing what I'm doing.  Air dry the lumber outdoors until it gets around 20% and then move it into shed with fans and a dehumidifier.  I can dry down to 7% in my 10x16 purpose built shed.  Insulate with polyiso foam instead of fiberglass like I did.  I added to foam to the inside to get the R value I needed.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Tinkerer
« Reply #4 on: July 26, 2021, 03:28:19 PM »
Thank you all for the input. I probably wouldnt be able to mimic airflow of the outdoors with four walls and a roof. But I like the suggestion of using it as a finish up to complete the drying process
  • I like trees.
« Reply #5 on: July 26, 2021, 04:49:55 PM »
Good luck.  Come back and show us what you come up with.  I hope to upgrade to an actual Nyle unit eventually.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Air drying, shed drying, oak drying and maple drying free Webinars
Started by GeneWengert-WoodDoc on Drying and Processing
Last post August 19, 2020, 07:41:18 AM
by Stephen1
Drying 6x6 and storing
Started by Madtrapper01 on Drying and Processing
Last post August 04, 2019, 11:08:46 PM
Kiln drying and storing
Started by DPatton on Drying and Processing
Last post January 01, 2021, 10:08:30 AM
by farmfromkansas
Drying/Storing under tarps - what are the risks?
Started by Pepe_Silvia on Drying and Processing
Last post April 09, 2019, 10:10:18 AM
by PA_Walnut
