Build a Dobro out of "Denim Pine" and watch the lawyers go nuts!!
I've seen this fairly often with red oaks. Blackened checks, shakes, and pockets of rot are numerous. You can tell before you cut it from the black crack or scar at the at the base of the tree. It sometimes oozes with a sickeningly sweet odor. The damage usually tapers off a few feet up in the log. Do you know the correct name and cause of this damage? (Image hidden from quote, click to view.)
Started by lxskllr on Chainsaws
Started by dirtymartini on Sawmills and Milling
Started by jimmac71 on Forestry and Logging
Started by sgtbowe on Timber Framing/Log construction
