Author Topic: 1979 F600 dump  (Read 1671 times)
Offline chep
1979 F600 dump
« on: July 27, 2021, 01:39:49 PM »
1979 Ford F600 dump truck
Recently restored (not by me) very clean and frame and body are in great shape.
New starter, alternator. Fresh battery, tune up plugs/wires.
Runs great. Dumps a cord of wood.  Has a hitch/reciever
370 v8 motor
2 wheel drive
Gvrw 22,500 you should see the spring pack on the rear!
No fuel gauge. Tach is hooked up funny (backwards). Has a slow rear brake leak. Fuel pump is trying to drain batt, So I installed a shutoff on the battery.
Split rims, tires are ok but weather checked.
Needs wiper blades.
5000$ obo
I have read and understand the ff rules on selling
Offline doc henderson
Re: 1979 F600 dump
« Reply #1 on: July 27, 2021, 01:51:06 PM »
I have the 1976 F700 with the Jimmy Carter governor that lets me go up to 60 MPH downhill.   8)  nice truck for logging/firewood.  lots of parts via LMC and others.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Re: 1979 F600 dump
« Reply #2 on: July 27, 2021, 02:18:28 PM »
Now there is a truck!
Offline HemlockKing
Re: 1979 F600 dump
« Reply #3 on: July 27, 2021, 02:19:27 PM »
I wish I was closer Im looking for a dump truck 1 ton for firewood
Offline chep
Re: 1979 F600 dump
« Reply #4 on: July 27, 2021, 04:58:38 PM »
I replaced the rear tail light today. all the lights work. hi/low left and right and brakes. the reverse light is not working currently.
It has had the bed chopped down from a longer one at some point in its life.
 That said it has a tighter turning radius then any modern ton truck and can sneak around pretty well. and would easily fit on most trailers.Hint hemlockking.... its a great old truck and gets lots of comments., but 2wd has def helped me want to be rid of it. i need 4wd for living on these hillsides
Re: 1979 F600 dump
« Reply #5 on: July 27, 2021, 09:22:01 PM »
I have pulled a lot of trees and made a lot of trips to the dump, and or picked up sand.  even my wife says the old dump truck has earned its keep.  tax and tags about 70 bucks a year.
Offline chep
Re: 1979 F600 dump
« Reply #6 on: July 30, 2021, 08:54:28 AM »
Open to offers!!!want it gone!
Online Southside
    • White Oak Meadows
Re: 1979 F600 dump
« Reply #7 on: July 30, 2021, 08:59:15 AM »
Kinda sounds like the cousin to Da Yoopers "Rusty Chevrolet"  :D
White Oak Meadows
Offline Ventryjr
    • The Rusty Mill
Re: 1979 F600 dump
« Reply #8 on: July 31, 2021, 06:22:03 AM »
Location?
-2x belsaw m14s and a Lane circle mill.
Offline chep
Re: 1979 F600 dump
« Reply #9 on: July 31, 2021, 07:25:31 AM »
Bradford Vt 05033
Offline wisconsitom
  • Deep in the larch
Re: 1979 F600 dump
« Reply #10 on: November 01, 2021, 11:43:38 AM »
I too wish it was closer.  Always paying to have stone hauled in-I could go get myself.  Crushed rock out of a quarry is cheap, trucking surcharges are not.
Doc, I can relate;  My next "ask" involves just such a piece of equipment, with similar initial resistance expected.
Far as I can tell, it's 6 of one, half a dozen of the other...
74 f600 wont start
Started by bigred1951 on General Board
Last post June 21, 2018, 01:55:36 PM
by bigred1951
Air Leak Jotul F600
Started by mitchstockdale on Firewood and Wood Heating
Last post February 13, 2019, 05:16:54 PM
by Pulphook
F600 Jotul Parts
Started by newoodguy78 on Firewood and Wood Heating
Last post September 07, 2016, 11:04:20 PM
by newoodguy78
1979 - 84 toyota 4x4 rear end
Started by firecord on Wanted
Last post June 29, 2014, 11:08:43 PM
by SPIKER
