Author Topic: Wood Owl bits in Boring Machine(Beam Drill) w/adapter  (Read 424 times)
Offline jacobcbass
  • Member*
« on: July 29, 2021, 10:05:36 AM »
I apologize if this may have already been discussed, but I searched without success.
If they would make an adapter to use WoodOwl bits with a boring machine(beam drill). Then we could switch WoodOwl bits from drill, to brace(w/ adapter), to boring machine(w/ adapter)!
Right now I'm using a WoodOwl bit that has the hex shaft cutoff and round stock welded onto the end with a flat side ground into it (from Tom via Jim Rogers). It works fine, but now the WoodOwl bit can't be used in anything other than the boring machine.
Here is the WoolOwl adapter to use with a brace: Square Hand Brace Adapters for Auger Boring Bits
Here's a YT video about using the WoodOwl Adapter with a Brace:
I just cringe at the idea of tying up so much money on Brand-New Bits to then modified them and end up not be able to use them in other tools, or as they were intended.
Please let me know if you guys found another way that works! Thanks Jacob
Got a working Snell boring machine! Need bits -any modern bits that will work?
Started by Preserved on Timber Framing/Log construction
Last post August 29, 2018, 04:20:45 PM
by Jim_Rogers
Bits for a James Swan boring machine
Started by JanPaul on Timber Framing/Log construction
Last post March 12, 2009, 01:01:53 PM
by moonhill
bits for barn beam drill.
Started by DansSawmill on Timber Framing/Log construction
Last post December 29, 2018, 10:21:52 AM
by DansSawmill
question
Beam Boring Machine Make/Model
Started by bhlaban on Timber Framing/Log construction
Last post September 20, 2018, 09:15:25 AM
by Jim_Rogers
