OT--String Trimmer Won't Idle Long
Started by GaTrapper, August 06, 2021, 09:31:11 PM
GaTrapper
I'm sorry if this is a little off topic.
I have a Stihl FS131 string trimmer.  Its maybe 2-3 years old. It gets used frequently during the growing season and chills out during the winter.  I only run non-ethanol in the machine. During the winter I crank it up every 2 weeks and let it run for a bit.
Currently, it cranks up easily and runs great. The issue involves idling. If I'm trimming and need to set the trimmer down for a minute, the machine will shut off within a minute or so. I changed the air filter and I am still experiencing this problem.
How can I correct this?
sawguy21
Try turning up the idle speed to just below where the head starts turning. The idle mix may need to be leaned out a bit as well.
tawilson
A plugged up spark arrestor has been the culprit for me a couple times.
2017 LT40HDG35 WIDE
Woodmaster 725
btulloh
Amen on the spark arrestor. Easy to overlook but can cause all sorts of symptoms.
HM126
Tom King
The spark arrester screen is held in the muffler outlet with one screw.  Take it out, and holding it with an old pair of pliers, heat it red hot with a propane torch.  Let it cool, and rub the ash off with an old glove on your hand.  Put it back in, and it should run like a new one.
sawguy21
That is worth checking out but a plugged arrestor won't allow it to rev up and develop full power.
joe_indi
This would be a 4 Mix engine (four stroke running on 2 stroke fuel). If the valves have not been ever adjusted that could be the reason. Several years ago I made a How To kind of video and uploaded it to YouTube, it might be of some help.
The carbs on these engines are a bit 'fussy'
My video
