Author Topic: Kiln chamber size  (Read 330 times)
Offline Mhaaland
Kiln chamber size
« on: August 15, 2021, 07:26:30 PM »
Im looking at getting the Wood Mizer KD150.  I see they give chamber size for 12 long package sizes but Id like to be able to dry 15 long slabs.
Does anyone know if there is a minimum and maximum square footage should for the chamber to have the KD150 to work efficiently?
Offline scsmith42
    • Whispering Pines Farm
Re: Kiln chamber size
« Reply #1 on: August 15, 2021, 07:47:40 PM »
You should be fine with a longer chamber but you'll need some additional fans, and it will take longer to heat the extra volume.  I've been running a 45' chamber with an L200 for 18 years.  It has 6 fans and sometimes I have to add a fan to circulate air to the ends of the chambers to keep the temps consistent from end to end.  You shouldn't need to do that with a 16' - 18' chamber though.
I'd go slightly overboard in insulating it so as to help keep the energy costs from climbing too high.
Tom's 3638D Baker band mill
L200 CHAMBER SIZE HELP?
Started by rs1626 on Drying and Processing
Last post November 06, 2005, 11:17:37 AM
by Gunny
question
Kiln Chamber
Started by Stump Jumper on Drying and Processing
Last post October 18, 2018, 10:40:32 AM
by K-Guy
Kiln chamber?
Started by Kevin_H. on General Board
Last post October 06, 2003, 05:39:39 PM
by Kevin_H.
Kiln Chamber
Started by jdtuttle on Drying and Processing
Last post December 17, 2010, 12:50:57 PM
by Doug_D
