Author Topic: Walbro carb rebuild kits  (Read 488 times)
Offline bundy
« on: August 23, 2021, 12:10:43 PM »
Is there any difference beside cost between OEM and aftermarket kits? Are diaprhagm and gasket kits enough or a more complete kit?
Offline Tacotodd
  • To learn and help
Re: Walbro carb rebuild kits
« Reply #1 on: August 23, 2021, 12:59:58 PM »
Usually they are enough,BUT, youíll have to be careful in certain circumstances because in THOSE circumstances, the pulse hole will be blocked or there is not enough coverage to prevent a torn gasket orÖ
Itís a sure enough bet that they will work if you get OEM, although itís not always possible (practical), then youíll have to take the time to carefully cut out the ones that you need along with the kits that you by online or whatever.
I hope that my (kinda) vague response answers your question(s).
Trying harder everyday.
Offline DHansen
« Reply #2 on: August 23, 2021, 09:55:04 PM »
Having the correct parts the first time will save frustration and time.  I have always thought the carburetor kits right from my dealer were very reasonable in price.  Like under $10.00.  and the kit has what I need and the correct gaskets.  No fun when the wrong parts create a new unnecessary problem.
Offline Real1shepherd
« Reply #3 on: August 24, 2021, 10:18:06 AM »
For a long time it didn't seem to matter if I bought a Tilly carb kit aftermarket or OE. From about 7yrs ago though, it did seem to make a difference. There seems to be no shortage of real Tilly rebuild kits on eBay. I go that route now. Usually they are from Ireland.
But for the Husky and Jonserds saws that used an impulse channel on the intake manifold, be sure to get the correct Husky gasket that covers the impulse channel completely....it won't come in the rebuild kit.
Kevin
Offline Mad Professor
« Reply #4 on: August 24, 2021, 03:30:34 PM »
Tillotson makes quality kits for other manufacturers carbs.
I'd avoid cheap Chi-Com knock off kits......
Need Help..........Walbro Carb!!!
Started by rahtreelimbs on Chainsaws
Last post August 23, 2005, 08:51:38 AM
by woodbowl
question
echo cs 680 walbro hda 271 carb
Started by vladislav95 on Chainsaws
Last post May 20, 2015, 12:06:02 PM
by SlimJim
Walbro HD-17A carb replacement
Started by pwheel on Chainsaws
Last post September 01, 2015, 10:55:53 AM
by pwheel
question for a mechanic about a Walbro carb
Started by ronbourd on Chainsaws
Last post February 24, 2016, 06:30:18 PM
by smmyb123
