Author Topic: Straightening a Logrite  (Read 2036 times)
Offline KirkD
Re: Straightening a Logrite
« Reply #40 on: September 02, 2021, 01:59:44 PM »
An old, very handy old man once showed me something that has worked very well for me whenever I need to bend anything, particularly anything hollow/tubular. If you can slip a spring over it at the bend spot, it is far less likely to kink. The tighter the spring the better. That Logrite is a little on the large dia. size but something like a garage door or motorcycle suspension spring would work. This does work surprisingly well in many applications.
Packing the inside with sand will work to.
Wood-mizer LT40HD-G24 Year 1989
Offline metalspinner
« Reply #41 on: September 02, 2021, 09:29:22 PM »
Traditionally, brass instrument tubing and bells (like trumpets and tubas) are filled with pitch and allowed to cool. Then they are bent around a form. The pitch is then melted back out. This allows for a perfect bend with no deformation in the material.
The new-school way is to fill the tubing with a soapy water solution then freeze it. After the bend, the parts are just hung over a tub to collect the defrosting water.
Straightening a bar.
Started by luvmexfood on Chainsaws
Last post October 03, 2014, 06:28:18 PM
by JohnG28
straightening a tree out
Started by edward johnson on General Board
Last post April 14, 2018, 10:29:19 PM
by mike_belben
Straightening a band
Started by cantcutter on Sawmills and Milling
Last post January 04, 2008, 08:45:21 PM
by Minnesota_boy
Straightening steel shaft
Started by sprucebunny on General Board
Last post November 14, 2006, 06:08:41 PM
by SwampDonkey
