Author Topic: Detroit 3-53 Camshaft / Balance Shaft Gear Question  (Read 445 times)
Offline JBMac76
« on: September 11, 2021, 08:50:44 PM »
Good Evening. Need a little advice on the counterweights on the balancer / cam gears. I was planning to do an in-frame on the my Franklin 132. Once I got the pistons and rods out of the way, I could see stress cracks on all the crankshaft journals. I had a military refurbished Game Goat 3-53, so I started the process of swapping everything from the old engine onto the Game core.
The original engine had the hydraulic pump driven off of the camshaft gear at the rear of the engine. Nothing was driven off the balance shaft gear, but there was a healthy pile of nut-locking plates, spacers, and a spare drive plate for a hydraulic pump bolted to the gear. I weighed all the plates, spacers and drives from each side, and they are almost exactly the same weight. I Understand what the counter weights do, but is the stack of "stuff" on the balancer shaft necessary? It doesn't seem that it would affect balance?
Offline bushmechanic
  • Someone else has it worse than you.
Re: Detroit 3-53 Camshaft / Balance Shaft Gear Question
« Reply #1 on: September 12, 2021, 08:04:34 AM »
It's a rotating part, weight needs to be the same or you will get vibrations that will damage the engine. If it was me I'd be using the Gama engine parts to rebuild the origional. Those surplus engines are made with an aluminum block and don't stand up well in forestry applications.
Offline JBMac76
« Reply #2 on: September 12, 2021, 01:24:09 PM »
In retrospect, that wouldíve definitely been the smart move-but Iíve never been accused of being smart! I think I was just tired of looking at that Gammagard engine sitting in the corner of the barn for the past 20 years! Switching out the end plate, all the gears to put the blower on the side that I wanted it, sourcing specialty gaskets for the oil pan and sleeves that go inside the water rings for the head has been quite the undertaking. Iíve got a friend with two complete 353s sitting in a junkyard, hopefully one of them has a good crank and gear train in it, and Iíll put the original one back together and have it as a spare when the Gama engine craps out.
Offline Logger RK
« Reply #3 on: September 12, 2021, 10:24:34 PM »
For the oil pan gasket,I just bought 2 of them & cut both & added  the longer piece on. I believe they have a 71 series oil pump which makes it a longer one. Iím on my 2nd Gama in my Hahn in 25 years. Iív gotten many hours out of them.
John Deere 4239 camshaft gear
Started by duckslayingpro on Forestry and Logging
Last post June 19, 2011, 10:23:53 PM
by UN Hooker
D37e-2 bevel gear shaft
Started by Jkauffman on Forestry and Logging
Last post October 14, 2021, 12:33:09 AM
by Gary_C
Ring gear on 8V-71 Detroit flywheel
Started by LeeB on Forestry and Logging
Last post June 04, 2015, 04:08:05 PM
by WH_Conley
Aesthetic and balance question about exposing joints
Started by jb9 on Timber Framing/Log construction
Last post August 06, 2015, 02:30:18 PM
by AlaskaLes
