Author Topic: Onan motor won't start on Champion 16 welder  (Read 244 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« on: September 13, 2021, 02:20:22 PM »
Bought this unit last early spring
Onan model #1216G-1/11199E
Had some issues, put a new coil on it. Ran fine till about 3 weeks ago. Would start, run a few minutes then quit. Sometimes would start back up and would run fine. Sometimes would have to wait 15-20 minutes and it would start up and run fine
Now it won't start. We replaced the fuel pump with an electric one. The vacuum style wouldn't keep the bowl full. Now we have enough fuel. Did run for 30 seconds earlier today, now nothing again
Thinking the mag is not producing enough power consistently, but not sure
Any idea's out there
Offline sawguy21
Re: Onan motor won't start on Champion 16 welder
« Reply #1 on: September 13, 2021, 03:04:54 PM »
Install a couple of inline spark testers which are cheap at auto parts store and watch the spark when it dies. If it turns yellow or quits you have narrowed down the problem. Was the coil OEM or an Amazon special? How many hours on the machine?
Offline mike_belben
  • Pulp Friction
« Reply #2 on: September 14, 2021, 09:46:06 AM »
Is this a breaker point or flywheel magnetic pickup ignition?
I have a 2 cyl onan in an old case tractor that just wont keep spark no matter how much breaker parts you throw at it.  Even name brand ignition stuff is offshored and unreliable now. Lucas, bosch.  Sad.
Isaiah 63:10
Offline Sedgehammer
« Reply #3 on: September 14, 2021, 11:07:00 AM »
Flywheel
I think we've got it narrowed down to the ignition control and exciter ring
Onan Mill Motor Maintenance
Started by Andries on Sawmills and Milling
Last post July 28, 2014, 09:25:30 PM
by Delawhere Jack
question
Onan 24 hp toasted. Next motor? WMLT40hd 1987
Started by mikeandike on Sawmills and Milling
Last post October 05, 2006, 11:46:50 PM
by mikeandike
Onan 24hp no start
Started by ARKANSAWYER on Sawmills and Milling
Last post February 17, 2006, 07:53:44 AM
by ARKANSAWYER
Onan 24hp woodmizer mill will not start, please help
Started by bitsy4643 on Sawmills and Milling
Last post October 12, 2010, 01:17:50 AM
by H60 Hawk Pilot
