Author Topic: Can this safely be cut down?  (Read 2159 times)
Offline sumpnz
« on: September 15, 2021, 07:16:05 PM »
Got a birch tree that is dying.  Normally Iíd just drop it, but look at the pictures and tell me if thereís a way to do so safely, without a bucket truck anyway.  It looks to me like a barber chair tree no matter how itís cut, unless from the top down.
Offline beenthere
Re: Can this safely be cut down?
« Reply #1 on: September 15, 2021, 07:27:16 PM »
Drop like any hard leaner.. small notch, plunge cut to establish a good hinge, and then cut back out to release the tree.
And keep your chin out of the way if it releases suddenly.  ;)
Online Southside
    • White Oak Meadows
« Reply #2 on: September 15, 2021, 08:31:38 PM »
That would be my go to answer but looking at the base it's clearly fractured and likely decomposed. Meaning holding wood is a crap shoot.
I would say trust your gut and know your limits. Get a machine to fell it or a bucket to work from the top.
White Oak Meadows
Offline treemuncher
  • Committed vegetation terrorist since 1997
    • TreeMuncher.com
« Reply #3 on: September 15, 2021, 09:16:56 PM »
With that much lean, he could get stump pull - not a pretty thing. I learned my lesson on a bad leaner many years ago that had that set up. Didn't get me but I learned a valuable lesson for the cost of adrenaline.
I'm no pro feller but I would notch above the horizontal crack, bore cut the hinge and then start from the back towards the bore cut to minimize any chance of stump pull. When she cracks, run. If its too dodgy to bore cut, just start from the back after setting the face notch. At least it's leaning away from the fence.
TreeMuncher.com  Where only the chosen remain standing
Offline sumpnz
« Reply #4 on: September 15, 2021, 09:45:19 PM »
It doesnít show up great in the pictures but there is considerable spalting on the compression side.
Offline Skeans1
« Reply #5 on: September 15, 2021, 10:30:24 PM »
Doing this itís liable to pop the hinge right out of the stump, same thing happens when boring in to put spring boards in always make sure your hinge is in front of your board or behind it.
Offline mike_belben
  • Pulp Friction
« Reply #6 on: September 15, 2021, 10:38:01 PM »
If it has room to go exactly where its leaning id cut a few gills in the front to be sure i dont get pinched.. Watch watch watch for motion.  Clean out whatever kind of notch you fancy but make it quick..  Clip the sapwood from afar by scoring with the tip around the sides then just race in with a backcut as fast as itll go and chase it off.  Dont slow down and dont count on a hinge of any integrity unless you core drill and determine its legit inside
Isaiah 63:10
Offline Runningalucas
  • Dazed and Confused
« Reply #7 on: September 15, 2021, 10:39:44 PM »
Do you have access to a tractor?  I've got a small backhoe that I use to push stuff over like that a lot; plus it'll help get rid of the stump more easily.
Life is short, tragedy is instant, it's what we do with our time in between that matters.  Always strive to do better, to be better.
Offline mike_belben
  • Pulp Friction
« Reply #8 on: September 15, 2021, 10:40:54 PM »
The compression side is already fractured from the load.  Itll probably want to pinch as you notch.  I might just bore cut the center and fly right out the back and run like hell.  It is definitely a dangerous job.
Isaiah 63:10
Offline Iwawoodwork
« Reply #9 on: September 15, 2021, 11:09:16 PM »
Before you even start get 2 good tow chains at lest 5/16 and wrap around the stump about 1-2 feet above the ground then about 2 feet above that wrap the second chain, then as stated before make a small face, about 1/4 or less of tree diameter,  in the side  of tree the direction it leans. I would never mess around with doing anything but a straight back cut on that nasty tree, the less messing around and the sooner the back cut is made the less time around that tree.
Offline sumpnz
« Reply #10 on: September 15, 2021, 11:12:14 PM »
Weíve rented a mini-ex a few times.  If we can do that again Iíll use that to push it over.
Iím strongly tempted to see if a fall storm knocks it over.
Offline mike_belben
  • Pulp Friction
« Reply #11 on: September 15, 2021, 11:14:25 PM »
Youd be better to dig the roots out than push too hard on that i reckon.
Isaiah 63:10
Offline Tacotodd
  • To learn and help
« Reply #12 on: September 15, 2021, 11:48:48 PM »
If itís of any value to you then youíll need to be extremely careful no matter how you approach it. But if itís not of value, just do it.
Just BE CAREFUL! We want you to come back, with zero medical problems from this dilemma .
Trying harder everyday.
Online Southside
    • White Oak Meadows
« Reply #13 on: September 16, 2021, 12:06:10 AM »
That's bad - really bad.  You touch that with a saw and she just might blow up.  The question is which way does the frag fly?
White Oak Meadows
Offline sumpnz
« Reply #14 on: September 16, 2021, 12:19:49 AM »
Yeah, I think the answer here is either hire a dude with a bucket lift or let nature bring it down next time we get some decent wind.  Supposed to get almost 4Ē of rain between Friday and Tuesday, over 2Ē just Friday.  Maybe weíll get enough wind with that storm?
Offline Ianab
« Reply #15 on: September 16, 2021, 01:29:18 AM »
On a positive note, you have passed level 1 of the "How to spot a hazard tree" test.  ;D
It's hard to give advice on that sort of thing over the internet. Could it be bored and felled like a regular leaner? Will it explode when a saw touches it? Can't really say  :-\ ???
Bucket truck or heavy machinery would be the safest option for sure.
Offline BargeMonkey
« Reply #16 on: September 17, 2021, 12:57:08 AM »
 ☝....  that tree is big enough to smoke the cab on a small machine, adding danger to it. Poke it at a comfortable height, get as much as you can and if it seems funny walk away, if it's 3/4 cut the wind will do the rest.
Offline kantuckid
« Reply #17 on: September 17, 2021, 08:52:28 AM »
A couple lengths of chain and my tractor would pull that down easily. Cut afterwards!
Online DMcCoy
« Reply #18 on: September 17, 2021, 09:28:55 AM »
That is ugly.
In your trunk picture - where I would place the hinge -is already cracked with the backside opening up. Man that is really ugly.
If it was me...
I would wrap it with 2 chains above that horizontal crack.
Put a long line on it a high as I could reach, long enough where I could pull it without getting hit.
Give it a light backcut with my arms extended and a clear escape route.
Pull it down with the cable.
-or-
blast the backside with a shotgun until it fell
-or-
leave it alone, which is safest, and I have 2 trees like that...
Offline kantuckid
« Reply #19 on: September 17, 2021, 10:13:26 AM »
Leave it be is the best answer...
How can I safely cut down this tree?
Started by 379hammerdown on Forestry and Logging
Last post February 26, 2007, 07:41:28 AM
by 379hammerdown
Where is the tension-how should I safely cut?
Started by BostonHandy on Ask The Forester
Last post March 29, 2018, 08:48:08 PM
by Southside
Working safely in snow
Started by OneWithWood on Forestry and Logging
Last post December 30, 2002, 04:42:04 PM
by Tillaway
How to cut this fallen tree safely?
Started by rmallaire on Forestry and Logging
Last post August 19, 2017, 08:46:38 AM
by TKehl
