Author Topic: Where to find this aluminum tubing???  (Read 720 times)
Offline caveman
  • In the land of the blind the one eyed man is king
« on: September 26, 2021, 04:56:50 PM »
My uncle gave me an CS mill contraption several months ago and I was wanting to add longer rails to it in order to mill some wide slabs.  Do any of you have suggestions of where to find the square tubing shown in the link below?
(Ebay link removed by admin)
Online btulloh
Re: Where to find this aluminum tubing???
« Reply #1 on: September 26, 2021, 05:26:14 PM »
Most likely itís a standard extrusion and you should be able to match it up from a vendor online. It will be in the general category of t-slot extrusions. If you post the full dimensions Iíll see what I can find if you like.
Online Old Greenhorn
    • Woodsman Forest Products
« Reply #2 on: September 26, 2021, 06:04:36 PM »
The company you want to check first is 80/20, here is the link: https://8020.net/search/?q=shapes
 They have hundreds of shapes it may take you a while to find what you want, but they are a leader in these extrusions and likely supplied the OEM. Take your time and use their search features. They have a lot of 'stuff".
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Offline caveman
« Reply #3 on: September 26, 2021, 08:33:51 PM »
Thank you, fellas.  I appreciate the guidance.
Caveman
Offline charles mann
« Reply #4 on: September 30, 2021, 02:32:08 PM »
@caveman
Were you able to locate the extrusion? I too am wanting to extend my cut width without buying a specified cut width
Temple, Tx
Offline ajsawyer
« Reply #5 on: September 30, 2021, 03:19:27 PM »
Can you post the picture? I have some extruded aluminum that's no use to me...
Offline caveman
« Reply #6 on: October 03, 2021, 07:57:16 AM »
<br
I apologize for the poor quality of the pic.  We may just do like Furby suggested in a pm, which was to just replace the aluminum with square tubing and make the fixture fit the CS bar we select.
Caveman
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #7 on: October 03, 2021, 10:45:00 AM »
Check out Misumi, probably everything you need there and they sell aluminum cut exactly to length, I thought prices were very reasonable. I bought stuff to mount a wixey gauge to my delta planer, anything there to do a project with.
Offline caveman
« Reply #8 on: October 03, 2021, 05:55:37 PM »
Thank you for your suggestions.
Caveman
« Reply #9 on: October 03, 2021, 07:25:51 PM »
What is the size of the square, the size of the t slot and the overall size? Im at work and dont have access to my mill frame, but a known dimension would allow for an easier search, even if the mounting hdwr had to be replaced, a person could find a size close enough, if not exact size, and make an order. I havent seen that exact style of extrusion used for the granberg mills, in the numerous sites iv looked at to build my router sled, but im sure any t slot extrusion of the same size should work.
Temple, Tx
How to find existing radiant heat tubing in cement slab
Started by mjeselskis on General Board
Last post November 29, 2016, 12:12:56 AM
by Saga Dan
i need to weld some aluminum without an aluminum welder
Started by Dan_Shade on General Board
Last post March 10, 2013, 05:57:30 PM
by smwwoody
What size tubing to use ?
Started by SCSawyer on Sawmills and Milling
Last post December 12, 2011, 10:41:07 PM
by Bill Gaiche
New Tubing install
Started by metalman1 on Chainsaws
Last post April 04, 2019, 02:29:05 PM
by Old Greenhorn
