Author Topic: Possible Error on Toolbox Uniformly Loaded Beam calculator  (Read 604 times)
Offline Mattjohndeere2
  • Here to learn.
« on: February 03, 2022, 09:40:01 AM »
Hey all - I was working through some load calcs with the "Uniformly Loaded Simple Beam For Dimensional Lumber 2-4" thick, and I believe there may be an error for Eastern Hemlock design values. When I select Grade #2, the allowable fiberstress is 850, and when I select Grade #1, the fiberstress is 775. Shouldn't those be the other way around?
Also - It seems the 850 value (assuming that's for grade 1) is quite different from the Manual Entry calculator design value table (1150). I do notice the manual entry design value table states "for timbers 5x5 and larger", maybe that makes the difference, but just wanted to point it out in case it could be an error.
I really appreciate the calculators and I use them all the time, so thanks very much to whoever puts in the work for them (DonP??).
Matt
Offline Don P
    • Calculator Index
Re: Possible Error on Toolbox Uniformly Loaded Beam calculator
« Reply #1 on: February 03, 2022, 10:15:10 AM »
Ruh-roh, don't trust it till I check. There's a couple of backups if you are sitting here in cold rain wanting do do something. Go to awc.org and use their span calc for dimensional lumber 2-4" thick. Hit their publications tab and download WSDD for heavy timber tables laid out by design value. Current design values are in the "Supplement" on that same publications page. (That's also the way to size lumber or beams for an inspector, that stuff is all code referenced)
I'll check back in.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Don P
    • Calculator Index
« Reply #2 on: February 03, 2022, 10:25:19 AM »
Excellent catch, thank you. That should be 575 for #2. Give me a bit gotta find the keys to get under the hood and check that array.
  • Here to learn.
« Reply #3 on: February 03, 2022, 10:45:30 AM »
DonP, thanks for those resources, and glad I could help!!
Offline Don P
    • Calculator Index
« Reply #4 on: February 03, 2022, 11:03:12 AM »
Here we go, Jeff already pm'ed asking if I needed a new way in but we should be good to go. That appeared to be a lone error, I did a real quick scan of the rest of the design values in that array, the patterns looked correct. That was a long day of data entry  :D.
What I've done here in several places where there are a couple of species groups, in this case the supplement lists "Eastern-Hemlock-Balsam Fir" as one group of design values, and then also lists "Eastern Hemlock-Tamarack" as another Group with slightly different design values. I cheated and used the lower design values and gave one option. In this case the only difference is the Balsam group has lower shear values so I used those in the calc. Usually if I'm bumping into whether those differences matter I'm having a basic size problem.
Offline Don P
    • Calculator Index
« Reply #5 on: February 03, 2022, 11:25:02 AM »
Just checked the design value list for the manual entry calc. Yes, those are from a different table in the supplement for heavy timber 5x5 and larger (table 4D). Those carry different design values so do make sure you are working from the right table.
I realized how much time I was spending at the kitchen table trying to figure out beams from my trees. When the forum got going I realized I was not alone and there ya go.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #6 on: February 04, 2022, 03:06:50 PM »
Thanks for all your work on those calculators, DonP.
Jim Rogers
Offline scsmith42
    • Whispering Pines Farm
« Reply #7 on: February 05, 2022, 11:04:50 AM »
Jim Rogers
Ditto Jimís comments.
Tom's 3638D Baker band mill
  • Here to learn.
« Reply #8 on: February 08, 2022, 10:09:53 PM »
DonP, thanks again. Those AWC pages are a great resource, I didn't know they existed, thanks for pointing them out.
Offline Don P
    • Calculator Index
« Reply #9 on: February 09, 2022, 05:56:23 AM »
They are that. For structural solid wood, awc.org is the resource. For engineered wood products, plywood, osb, trusses,LVL, glulam, CLT's, etc check out apawood.org. Since those include our typical bracing products take a look at their framing, wind and bracing guides.
Offline customsawyer
    • The Custom Sawyer
« Reply #10 on: February 09, 2022, 06:10:43 AM »
Sure is nice to have these resources at our finger tips.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline Don P
    • Calculator Index
« Reply #11 on: February 09, 2022, 07:52:58 AM »
I don't think I've said in some time. The calcs here are a little different than most, the "coding" is visible. I was hoping that people who knew more about computers and/or engineering would read the code and keep improving them. So far that hasn't happened, but you never know (especially if I bring it back up  :)).
but, the quick check I, or any of us, could have done in the moment the other day is... right click>view source. A window should pop up with the "script" the calc is running. You can't modify from there but it is a quick read of the code.
Uniformly Loaded Beam Overhanging One Support
Started by Sedgehammer on General Board
Last post June 06, 2021, 07:14:45 AM
by Don P
Toolbox Board Foot Calculator
Started by dirtymartini on Sawmills and Milling
Last post June 23, 2021, 10:13:27 AM
by dirtymartini
lumber weight calculator in the Toolbox
Started by simonmeridew on Forestry and Logging
Last post January 16, 2010, 09:36:49 PM
by timberfaller390
Forestry Forum Toolbox Lumber calculator problems
Started by broker farmer on Sawmills and Milling
Last post February 03, 2006, 11:29:08 PM
by Tom
