Strapping for lumber
Started by Wlmedley, May 19, 2022, 09:42:00 PM
Wlmedley
Does anyone use strapping to bundle lumber or slabs? If so what kind would work the best and also be economical.Also would this help prevent warping when air drying lumber.
Bill Medley WM 126-14hp , Husky372xp ,MF1020 ,Homemade log arch,GMC2500,Oregon log splitter,Honda Pioneer 700,Kabota 1700 Husky 550
doc henderson
I started with steel, but the clips were not adjustable, and the metal caused rust up against the wood.  I now use plastic with buckles that can be retentioned.  I have both.  I have some stainless steel that is highly tension able, but expensive for utility grade.  three kinds of tensioners, but a variety of stock banding.  best to have a cart to organize.  I can get details later.  I patterned the plastic stuff after what Jake @customsawyer used in 2018 at the sawing project.
Wlmedley
I guess I should have did a search.Saw I bunch of posts where you all discussed this in the past.Thanks for answering.I'm learning slowly but surely  :laugh:
