Four sided planer moulder
Started by Stormo, June 03, 2022, 03:39:26 PM
Stormo
Looking to purchase a four sided planer moulder. I have been looking at the Wood Mizer Mp360. Looks like it is a year out. Was wondering if anyone has a suggestion on the best machine to get. Most of what I will be doing is cedar and Fir tongue and grove boards.
Southside
Give Woodmaster a call and look into their WM4000. I am very happy with mine.
White Oak Meadows
customsawyer
What kind of production are you looking for?
www.thecustomsawyer.com
Stormo
As far as production I looking to do 10000 to 15000 lineal feet per month. I do also do some beams (6 x 8  ) that would be surfaced on 4 sides.
Stephen1
I am also looking into this .
We have an order this summer for 2000 sq ft of ash flooring and other inquiries.
I just lost out on a nice portable sawmill job as the planing had to go to another shop. These other shops are 2-6 months out.
It seems the planer fits nicely after the kiln.
Walnut Beast
I think Southside runs his pretty much everyday
customsawyer
That amount of footage will take 1 hard day or 2 easy ones through my Pinhero. I normally set it at about 48 ft per minute. As much as I get bored feeding my planer at my pace I would not want to have a slower machine.
YellowHammer
You asked "what's the best machine to get?"
The guys who plane my wood use a Pinheiro and it is a commercial, wood eating, day in and day out, center piece of a business that runs molding for a living.  They have been planing my wood for over 10 years, with the same machine, and it was old back then.  It just runs, requires minimal board prep, and takes off whatever needs to be taken off.  It is a 4 sider, but I only have them run the top and bottom head.
It is not much different than the Pinheiro that Jake runs, and he runs it hard, and its doesn't care.  He does semi truck loads of wood with it.  You can buy a used unit for a decent price, and it still will have 20 years of commercial life left it it.
Anyway, after seeing two of them run, with the machines not even straining, there is no doubt what I would buy.  The footprint is actually not that large, less than my double sided flattening planer.
There are lots of good 4 siders out there, and I have seen others....but I haven't seen anything better than these machines.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
customsawyer
There is some other machines that will handle that amount of 1X material. The Pinherio has the advantage of being able to handle bigger timbers and wider material than most in the same price range. I think mine is a '97 year model 800. This gives me a 8x25 capacity. It can only run top and bottom at heads at 25" and around 20" wide with the side heads. I'm not sure what the max width is with the side heads as I have never tried to max it on that. Your normal 5,6 or more head molders can be had reasonable as the Pinherio but when you go over 9" in width the price goes up fast.
Stormo
Thanks for the help. I will be calling Woodmaster as well as looking for an older used machine like the Pinhero. Any Idea where to find one?
Walnut Beast
Quote from: Southside on June 03, 2022, 04:35:19 PM
Good choice but they are backed up till after 2023 and 27k+ now
customsawyer
When looking at buying a used machine, see if any extra heads or knives comes with it. I bought my Pinheiro around 8-10 years ago for 24K. I have probably 30K in heads and knives. I didn't have to buy all of them at one time but they do add up over the years. One of the draw backs to the Pinheiro is most of my knives cost a little more. This is because they are thicker stock so they will hold up to what the machine can do.
A good place to start looking for used equipment is Sawmill Exchange. They normally have a banner at the bottom of every page on here. Or can be found on the left of the page.
scsmith42
Quote from: Stormo on June 05, 2022, 09:09:20 PM
Comparing a Woodmaster to a Pinheiro is like comparing a Ford Ranger to a Kenworth. There is a vast chasm of difference between them in turns of capability.
Tom's 3638D Baker band mill
YellowHammer
YellowHammerisms:
Walnut Beast
And I'm sure there is a major price difference between the two. Southside seems to be running his like a Kenworth everyday! And it's still going strong
Walnut Beast
Find me another company of a comparable 4 sided planer of the capabilities it has at 27k with a 5 year warranty on pretty much everything on the unit. And 60 days running it or send it back for your money back.
YellowHammer
No warranty on used Pinheiros, I assume.  However, when Jake asked me to question the guys who run the one locally, 40 hours a week, for a few decades, how ofter they break down, the foreman shook his head and said "I can't remember the last time it was broke down, maybe 10 or 15 years?"  Then he turned to another guy and asked and he said that he'd been working there at least 10 years and it was always running.
One down side may be the amount of people required to feed it.  When they plane my wood, about a 25 foot flatbed trailer load per week with it, they generally use 3 guys but when doing big live edge slabs, 4 or even 5 people, 2 to feed, 2 to catch, and one to make adjustments if needed.  It will plane a 24" wide, couple hundred pound live edge slab, both sides at the same time, no problem.
The company has it's own grinding and sharpening shop, so they generally can only run a week before they dull and need to replace the blades with newly resharpened ones.
They are out of production now, I wonder what is the closest commercial equivalent to it?
YellowHammerisms:
customsawyer
YH When you say they are out of production are you referring to Pinheiro or your local guy? I can still contact River Valley Machinery in Maine and get parts for mine. I was under the impression that River Valley was still getting fairly new machines in. I actually got my used one from there as they refurbished it some before they sent it to me. They was a little slow and that was before covid. One of the main reasons I'm recommending them to the OP is he mentioned running some timbers. I don't know the max size Woodmaster can handle but I know the Pinheiro can handle bigger than I want to be having to feed it or catch on the other end.
As to the number of men it takes to run it. I normally only use two men. One to feed and one to catch. I ran about 8000 LF through mine yesterday. We never had to get in a hurry. Had to change the set up 3 times (which I'm getting better at). Even got shut down for about 1.5 hours due to thunder storm moving through. Still had it all done in a 9 hour day on the clock for the hired man.
Edit: None of this material was flooring. Flooring is a much tighter tolerance. This was square edge material and V-Groove paneling. Where this machine shines is that none of the lumber ran yesterday had to be pre sized. I unloaded the truck Monday and put it in a shelter. Grab the first pack yesterday morning, with the forklift, cut the bands and started making a finished product. These were 1.125x7.75-8.25x16 from a local big mill. Finished to a show face on V-Groove of 7.125. On the boards that are 8.25 wide it is taking a extra half inch in width off of the board and it doesn't care. I have feed 1.375x7.25x16 through and finished at .75x6x16 and it will eat them as fast as you can feed them.  I'm sure some other 5, 6 and more head machines can do the same, on up to 2" thick boards, but I don't know how big of timbers they can do.
Walnut Beast
There is no doubt your machine is a serious machine hands down!!
YellowHammer
Both....I thought Pinheiro had gone out of business and only aftermarket parts were being built by other companies to keep the existing machines in service.
Unfortunately, the company who does my planing has asked for a "temporary break" because they said I was killing their guys....or more appropriately the tonnage of slab wood I was having them plane was too much. :D :D   I said that's why I bring it to them, I do the lighter stuff with my planer, and I pay them to do the heavy stuff, or the wood I don't want to. :D :D
They plane and mold lots of stuff through it, every shift, but it takes a toll on them.  Planing pallet after pallet of wood is monotonously heavy and they are having employee problems.  One guy is having back surgery, another has COPD (I told him if he'd quit chain smoking things would be better), another guy just walked out and quit, and as the foreman says "Nobody wants to work for a living anymore."  So they are making adjustments to the employee workforce to keep the machine fed.  The machine is outworking all of them, it just eats wood and is hungry....
I was there the other week and they had just finished loading a semi truck with some 16 foot sticks of molding, the last of a shipment of 22,000 linear feet or a little over 4 MILES through the machine...I don't know how long it took to run that much, but it was just another day or two at the office for the old girl.
Here's some of what I bring them, most every week, for maybe 8 years now.  This load was a little more than usual, but it all goes through the Pinheiro rough and comes out smooth.  We also plane about one pallet every couple days though our CanTek double sider, but I try to outsource as much planing as possible.  I really don't much like it....
YellowHammerisms:
Old Greenhorn
YH, you should have told them they just have to 'take steps to save steps'. :D Problem solved. ;D
customsawyer
My feed rollers are getting worn. River Valley called me last summer and asked how my machine was running. They explained that they were about to place a order and it would be a few months to get the container in from Portugal. If I thought I might need some thing that it would be the time to place the order as they could add it to the order and shipping could be shared by all. I ordered all 3 infeed rollers and bearings. They arrived around March, with a cost of about $4500.00. I haven't installed them yet as I'm not looking forward to it but I have them in inventory when the time comes. I didn't think the price was to bad when you consider I paid 24K for the machine and other than a few mistakes from me and a mouse that got cooked in the control panel (which fried the top head motor) this is the only thing I have had to get for the machine.  Any time you can get a machine that will produce like this planer will, with that low of a cost, it isn't hurting you for what it can make you. Either one of my big planers actually make more profit per run hour than either one of my LT70s. I just don't have the volume of work yet to run them full time.
Walnut Beast
Yellowhammer looks like your picture didn't get in there. That explains why you are farming out your planing still. I was wondering about that after you had your new machine and dust system setup. Custom you could sell your machine now for more than you paid for it. Good used units are 35k
teakwood
Yellowhammer, where do you get so much rough sawn wood from every week? don't tell me that you saw all by yourself and Marta with all the other stuff you have going on.
customsawyer
I've shared this before but figured it might fit in with this conversation.
Making V- Groove paneling with a Pinhero 4 head planer - YouTube
