Author Topic: How to speed up firewood drying  (Read 1410 times)
Offline Ianab
Re: How to speed up firewood drying
« Reply #20 on: June 21, 2022, 02:09:32 AM »
I heard a story, maybe a legend🤔 of Canadians to the north of here dropping paper birch, and then running a kerf the length of the tree with a chainsaw. The bark would curl away from the cut and let the wood dry
Makes sense. If the wood you are trying to dry has a layer of bark, it has to slow the drying. Wood loses moisture fastest through the end grain, so getting it bucked into 12-18" lengths will be the most use. But splitting / peeling the bark must do "something" to speed the drying of log length wood.
Offline Wood Shed
  • Retired antique tractor guy enjoying my Tree Farm
« Reply #21 on: June 21, 2022, 05:07:07 PM »
In my experience leaving a tree sit with the leaves intact to dry naturally will definitely lower the moisture content, have read that it will lower it to 20%, have not checked that but I have read that somewhere (probably here).  Split and stack off the ground like on a pallet in an area that it will get air circulation and protection from rain.
A society grows great when old men plant trees whose shade they know they shall never sit in. -Greek Proverb
Offline OddInTheForrest
« Reply #22 on: August 10, 2022, 04:22:33 AM »
i have done this with white birch here in norway, but then left it for 4months. Was ready to burn after splitting.
There is a way, used in the small circles around restoration of old log buildings here, called "Ring-barking".
They cut of a 1m / 3ft piece of the bark at the bottom of a standing tree, and leave it for about a year. It dries the tree up, and makes it ready for axe-work and shaping rigth after its cut.
I have speculated in doing the same with a few trees in my firewood block, but havent gotten around to it yet.
How to Speed up 8/4 Drying Time
Started by Sawdust Lover on Drying and Processing
Last post January 13, 2014, 08:42:41 PM
by Too Big To Fail
Speed drying options
Started by PAmizerman on Drying and Processing
Last post January 21, 2021, 06:58:20 AM
by petefrom bearswamp
Speed drying/seasoning American Hornbeam?
Started by malignity on Drying and Processing
Last post January 29, 2016, 06:55:08 PM
by Clark
Using OWB for drying firewood?
Started by DaleK on Firewood and Wood Heating
Last post February 25, 2014, 07:29:48 PM
by NWP
