I have no experience with that saw, but you tried tightening the chain by resting the bar nose on something like a log and then lift the other end by the handle so that weight rests on the nose. Now tighten the chain to your liking and then tighten the nuts while still resting weight on the nose. This is the way I always tighten chains and then the nuts. You just need to get the nuts a little tight and then you can set the saw down to get a better hold to tighten the rest of the way.
Started by Mikeinkaty on Chainsaws
Started by Schramm on Sawmills and Milling
Started by schmeg on Chainsaws
Started by doo_hicky on Chainsaws
