Author Topic: Nyle L200  (Read 657 times)
Offline Jmike
Nyle L200
« on: November 25, 2022, 09:47:41 AM »
Regarding the Nyle L200
The way I understand it when reach the "end of cycle" the MC setting has been reached.
To set the pitch you set the temp to 150F for 24 hours. How do you get the controller to stay on
for 24 more hours if the MC has reached the setting?
Thank you
Offline K-Guy
    • http://www.nyle.com/
Re: Nyle L200
« Reply #1 on: November 25, 2022, 08:32:52 PM »
To st the pitch, turn the compressor off, set the dry bulb to 160, and set the final moisture to zero. Otherwise the probes will turn the heat off and the screen will show end of cycle.
Nyle Service Dept.
- D. Adams
Offline Jmike
Re: Nyle L200
« Reply #2 on: November 26, 2022, 04:42:09 AM »
"Set moisture to zero"
Thank you, I guess I should have thought of that.
Offline Rick Fisher
Re: Nyle L200
« Reply #3 on: November 28, 2022, 11:13:10 PM »
Does the Nyle 200 reach 150 degrees or 160 degrees or do you need the heat booster with it ?
Offline K-Guy
Re: Nyle L200
« Reply #4 on: November 29, 2022, 07:54:38 AM »
If your kiln is tight and well insulated, it can reach 160°F but it may take a while, the heat booster speeds the pre-heat up and heat treat up.
Nyle Service Dept.
- D. Adams
