Panel Glue up fixture?
Started by Brad_bb, January 27, 2023, 05:50:57 PM
Brad_bb
Do any of you use a panel glue up fixture?  What is a good one?  How well does it work?
Dan_Shade
Are you looking for production, or ease of glue up?
I saw a really interesting setup that a guy used to glue table tops.  The setup was bar clamps set up against the wall, so the glue up was vertical and did not take up a lot of floor space.
lots of dull bands and chains
Don P
There are companies selling that setup.
We had the clamps from an old manual glue reel as backups to the RF gluer when I worked on a panel line. If you could score one of those and sell what you don't need. Those are a ferris wheel of industrial bar clamps. By the time it comes back around the panels are dry and ready for unloading the dry one and laying up a fresh one.
The scale is wrong but the machines are neat, the edge glue machine was the panel gluer there and in a cabinet shop. He had tooled up and we made panels and doors for other shops as well. Now you are spitting out a load of panels a minute.
New Woodworking Machines, Used Woodworking Machines, Woodworking Machines | Wilkesboro, NC (rosenquistllc.com)
Crusarius
I saw these a while ago and thought it would be great to have a few or 30 :)
Rockler Deluxe Panel Clamp, Single - Rockler
Brad_bb
Not for production.  I'm trying to reduce the struggle of dealing with a bunch of loose clamps.  I just had to glue up 3 shelves, and I had to do one at a time and do it on the floor with my clamps and calls.  My new shop is not properly set up as I have to store materials that need to stay dry in conditioned space.  So I'm making the best of it.  I was reading about the Fulton Panel Max System today but not sure how good it is.  I just looked at those Rockler panel clamps and unfortunately the min thickness is 3/4".  It's not unusual for me to glue up 1/2"  or even 3/8" panels.
I think I'd be ok doing one glue up at a time if it were easier to clamp and unclamp.  I expect at some point in my house build that I'll need to do a bunch of panel glue ups.
Dan_Shade
How many clamps do you need to accommodate?
Andries
The Lee Valley panel clamps work for me, the key is to use dry, straight and strong cauls.
LT40G25
Ford 545D loader
Stihl chainsaws
doc henderson
looks like the slant rack could be fabbed up, so the panels can be clamped.  I do mine on my table saw with two clamps under,  after in place, I stand the panel up and place clamps alternating side to side.  I may make something, that can go against the wall, but fold out as needed.  I use a glue roller to spread the glue, so it is less likely to run off.  I use biscuits and a dead blow hammer.  the Rockler things look like mostly a fancy expensive caul.  I like lee valley but I will stay with my pony pipe clamps.  how big of panels do you anticipate needing?  how many?  good luck!
Brad_bb
That's my inclination too Doc, something out of the way that uses gravity to assist.  Just trying to
See if there's a really slick system out there, before I try to reinvent the wheel.
doc henderson
maineshops
I use a 4x8 sheet of particle board. Glue a 1x2 strip on the top and side at right angles.
I set my panel in dry and drill holes for simple cam clamps I make out of wood. Or you could use a block and a wedge. I've used this system for 50 yrs or so with good results. Dan
Phil:4, 13
scsmith42
Tom's 3638D Baker band mill
Crusarius
how do you guys clean those rollers? does the glue just peel off after it drives?
doc henderson
yes.  look as good a year later as the first day.  they have spiral flutes like the fancy stickers.  it spreads a bead over the edge surface, like stripes and you can handle the panel boards without it running over the edge and creating more clean up.  you can really get the right amount, so less waste and squeeze out without dry spots.  I did order one with the bottle to try.  i also use the glue bots for my gallons of titebond.
21incher
This is not about a glue up fixture but I find the Bessey offset blocks very handy for things like face frames. They don't cost much and make setting up clamps easy.
They lock the clamps at right angles and can also be used for singles
They set just below the pads and dried glue peels right off
You can see the mounting holes they have that accept flat head screws for permanent fixtures
I bought 2 sets of 4 and find them useful for some glue ups and they let me work quickly without worrying about clamp position. Used to be about $15 a set but I think inflation may have increased the price. Not a glue up fixture but I use mine all the time. How did this post get so wide?
scsmith42
Quote from: Crusarius on January 28, 2023, 02:06:56 PM
I wash mine in warm water immediately after use.  However, the glue will peel off after it dries too.
Don P
The "clamps" on one of those glue machines was firehose inflated with air pushing on a row of sliding blocks, there was a stack of dummy boards to fill the 4x8 opening alongside whatever panel size was going in. A hose can conform and give very uniform pressure.
And then I went to a shop running hydraulic cold presses. I've got about enough bottle jacks to clamp a beam between a slab and something serious overhead.
Someone mentioned a frame and wedges. The assembly tables we worked on to feed the 60 hydraulic cold presses above, were just angled steel tables with a square steel tube perimeter frame. We had various size pairs of opposing wedges to clamp parts together, we would pin and go to the press for face lamination but leaving something wedged like that on the table would work fine for edge gluing. A boatbuilder that was slumming with us in one shop said "You can clamp anything with wedges" He was right.
Brad_bb
Is it just my computer, or did the format of this post get really really wide off the screen somehow?  How does that happen?  Can it be fixed?
Other post I go to aren't wide like this?
I've looked at some other clamps- woodpeckers clampzilla, and Frontline wood clamp system (from Austrailia).  The Frontline is very expensive, too expensive for me.  About $1000 for 2 clamps.  Woodpeckers clampzilla is a more viable option depending on the width you get.  The widest is about $650 for 4 clamps.  It looks better built than the Rockler.
Brad_bb
Now I just discovered the Plano glue press (from Logosol) on Amazon.  Watching some youtube vids.  Looks a lot like the Frontline from Australia, but lower cost.  It's in between the Woodpecker and the Frontline at $800 fro 3 clamps.  This system is wall mounted and looks more user friendly with how the clamps come apart at the top to insert the boards. More food for thought.
Plano Glue Press - YouTube
I looked at the Lee Valley hardware but it doesn't seem to clamp the tops and bottoms of boards but only the sides.  I found a video that says they do put pressure on top and bottom when the studs can't when squeezed, but I wonder how much pressure it can put?  I'm thinking the Plano or woodpecker would apply more pressure?
doc henderson
yes but they are made from "al you minimum" :D :D :D
Dan_Shade
My thoughts are that a lot of this stuff is unnecessary.
It's marketing.
I prefer parallel clamps to bar clamps, but both work.
A quality glue up starts with quality prep.
If your boards are flat and straight, you really don't need much help to glue them up.
A commercial cabinet shop will have different needs than most of us.
I did 8 panel glue ups once for two cases. I clamped and stood them up side by side (another benefit of parallel clamps).
Brad_bb
@doc henderson
1. Are you now British?
2. Do you know this or are you assuming?  Is this a negative?  Sounds like they've been making them for a long time.  If they were not strong enough.... do you know that they are not strong enough?  Just asking the questions.
Brad_bb
@Dan_Shade
I've been doing it with parallel clamps and calls and c-clamps.  I'm trying to find a simpler way with less clamps and fiddling around needed.
doc henderson
I am not British but dated someone in residency who is! :) (note the laughing emoji)
I think they look great and watched video.  they are cauls and clamps all in one.  to get as pictured it would be 1600 bucks.  I aluminum (how ever you say it) is a great material, light, slow to corrode, no rust.  If you have many to do, might save time and add quality.  I use biscuits, and tune my jointer to make good edges.  They are marketed by a company but it said somewhere that the manufacturer is no longer in business.  The lady in the video said they were alum.
It is a lot of money unless you plan to use them often, in my opinion.
rusticretreater
Quote from: Brad_bb on February 03, 2023, 12:43:12 PMIs it just my computer, or
It looks like it started on the second post.  It's probably some HTML(computer stuph) that got posted along with the message.  We
don't see it, but it tells the browser how to format the screen.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
