Sawmill Maintenance/Repairs
Started by Magicman, February 23, 2023, 04:25:03 PM
LeeB
I thought I had remembered that the LED's were a mod but I had to go look at my mill anyway. I would have been terribly embarrassed if they had been there and me not to have noticed after all these years.  :D
Dad2FourWI
As we continue our mill maintenance.... having great success with the new speed pot replacement. We decided to clean out the area by the Up/Down Assembly.
Took both front and rear panels off and wiped down and blew out.... it was really dirty, quite embarrassing!  :-[
When my son found a grease zerk fitting on a bearing... looks like the Bearing, Flanged Up/Down  part no: 014090 in the parts manual - even though the manual does not show a grease fitting in the drawing.
Well, I have to admit that we have never greased that bearing.... and I have asked other sawyers here if they knew about this grease fitting and they too have not been maintaining this fitting.
I just thought I would add this to the list because there might be other sawyers who don't know about this well hidden zerk/grease fitting! LOL!
Cheers!
LT-40, LT-10, EG-50, Bobcat T750 CTL, Ford 1910 tractor, tree farmer
That is a very slow operating bearing and a good greasing will last many years.  Sometimes during cleanup I may even remember that it is there and give it a few pumps.
Dad2FourWI
LOL!!!!!! OK, I will not worry about that but I will add it to the yearly maint list!
Thanks @Magicman , your experience is much appreciated!!!!!
If you ever get to central Wisconsin, let me know and lunch is at my place!!!!!  8)
-Dad2FourWI
WV Sawmiller
   Dad brings up a good point that I wish came with the operator/maintenance manual for the mills - a simple chart showing/listing the locations of all the grease zerks so when we grease the mill we don't miss one. I grease every fitting I know of but if I am missing one I don't know it. I cant imagine it would be hard to generate one at the factory by doing a simple search on Grease fittings. Maybe the mill makers are reading this and can generate one in the future.
Sod saw
Some of the old, old tractor manuals had those lube locations on a picture  of the machine.  Many manuals had multi pages of different views showing locations of grease fittings and fill caps for oils etc.
LT 40 hyd.          Solar Kiln.          Misc necessary toys.
It's extremely easy to make things complicated, but very difficult to keep things simple.
Chuck White
IIRC that zerk is to be greased every 1,000 hours.
On my mill, I greased it any time the shield was off!
Dad2FourWI
Yes, I still refer back to my old Ford manual for the locations of the zerks... that is exactly what I wanted for my mill.
I said this same thing to the tech support at WM.... and he said to "Get to know your mill better".
OK, he is correct, but gee, not exactly what I wanted to hear! LOL!  :D
moosehunter
Started my " I wish it was yearly but don't think I got to it last year " in the garage maintenance.
Stainless bunk caps off, ground off the rust, rust converter, black equipment paint. I'll wait a week for the paint to dry then put the caps back on.
Changing all fluids and filters. Control boxes all open to check for loose connections and green goonies.
If anyone knows, tell me about pulling the idler side band wheel. The bearing has always had some side to side play, not worried about that. Now to seems loud when I free spin it. I would like to get it off so I can feel the bearing with my fingers. I may have to borrow/ rent a large puller.
Next weekend the bunk covers will go back on the I can go through a complete adjustment on the band / head / setworks.
Off to see a movie with my 7 yo grand son this afternoon.
mh
Higher than my expectations
doc henderson
what movie?  My daughter and I go to all the new great animated movies.  the same ones have been shoeing here for 2 months.  she is 24 with a degree in animation.
Smallmill
"If anyone knows, tell me about pulling the idler side band wheel.."
Take the bolt out and it comes right off. No force necessary to remove in my experience. I've replaced the bearings more than a few times and they always seem to have some play in them.
GAB
Quote from: doc henderson on March 05, 2023, 10:48:50 AM
Doc:
Thanks for the education.  I had never heard of a degree in animation.
GAB
doc henderson
many of the classes are also in game design or graphic design, but only one college in Ks offers that bachelors degree.  they do the computer style.  My daughter like the old 2 D.
Thanks GAB, Doc!
moosehunter
Smallmill; it won't just slide off. Tried some pressure with a hammer and brass drift. It ain't movin.
Doc, Puss N Boots. Some of that computer animation is impressive!
mh
OlJarhead
(15) How to Replace a Bandwheel Bearing - Wood Mizer LT40 - YouTube
Sure didn't slide off for me! LOL
and I learned to leave the C-Clip on and let a machine shop deal with it :o ;D
moosehunter
OJ, thanks for the video. I was pretty sure that is what I would need to do. mh
OlJarhead
moosehunter
OJ , I like the sign on your mill! It looks familiar
mh
Stephen1
Quote from: caveman on February 23, 2023, 04:49:05 PM
That is not a bad price to be back in the saw seat.
When I removed the blade after sawing on Monday, I saw a oil fill line I never noticed before. I did not see anywhere to put oil or even check it near the sticker.  Please provide me some guidance on this.
This is on the drive side behind the blade wheel.
I am going to say it is the oil level for the drive side main bearing.
Sorry I replied before I read the whole thread
I check my Drive belt Tension 1st of the week, ATF everything at the same time, chain, felt, all nuts and bolts. I have a small pump oil can that I fill and go around the machine until it's empty.
I do need another chip deflector, I am on #3 on this mill.
OlJarhead
lol @moosehunter I think a lot of us use that one 😉
barbender
I don't remember how I got the idle side bearing off. It may have just slid off once the retaining bolt was removed, or I used a 3 jaw puller. Either way it didn't fight me enough for me to remember it🤷
 I've changed those bearings several times, now I upgraded my idle wheel and it has a much larger single single bearing.
OlJarhead
I used some Anti cease after replacing the bearing on mine at the advice of WM.  I'm hopeful it goes smoothly next time LOL...and I don't plan on taking an eye out next time either, so I'll let the machine shop take care of that...er the C-Clip :P
wisconsitom
@barbender, on that idle side upgrade, I see you used a large single single bearing.  I take it that's a double bearing?😉
Ask me about hybrid larch!
Not much to write home about but today it was "find the insulation worn" ground (pulsing) wire that feeds the LubeMizer and repair the insulation.  A bit of rerouting and couple of zip ties will prevent this from happening again.  The pivoting motion of the engine when the auto clutch is engaged was the culprit that caused the problem.
So afterwards it was change the engine oil & filter and also both of the fuel filters.  Fueled up, filled the blade box, and I should be ready for Monday.
Dan_Shade
My recent adventure manifested itself in a massive oil leak on the top end of my kohler 25hp engine.
I changed out the breather gasket
 and the breather filter, and I think I fixed it.
lots of dull bands and chains
