A few notes to help others on the L53 sytem
Started by blackhawk, March 22, 2023, 01:36:26 PM
K-Guy
Nyle Service Dept.
- D. Adams
blackhawk
Is there a resolution to this problem or do I just have to live with it?
Lucas 7-23 with slabber. Nyle L53 kiln. Shopbot CNC 48x96
doc henderson
BH can you try going to 2 and then zero to see what difference this makes.  sounds like a spread to keep the cycling on and off to a minimum.  Maybe with that understanding you can live without a true fix if there is none.
YellowHammer
Yes, it is generally called hysteresis, and for example, in air conditioning systems can be as wide as 4 degrees, 3 degrees normally about minimum around the controlling parameter, and is used to protect "short cycling" or rapid cycling of freon systems, the firing of the capacitor on the compressor, etc.  I was actually surprised to hear how tight the Nyle hysteresis band is, and I the grand scheme of things, in the real world it is set wider, and is there to protect the mechanical system.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
blackhawk
Quote from: YellowHammer on January 03, 2025, 09:06:19 PMYes, it is generally called hysteresis, and for example, in air conditioning systems can be as wide as 4 degrees, 3 degrees normally about minimum around the controlling parameter, and is used to protect "short cycling" or rapid cycling of freon systems, the firing of the capacitor on the compressor, etc.  I was actually surprised to hear how tight the Nyle hysteresis band is, and I the grand scheme of things, in the real world it is set wider, and is there to protect the mechanical system.
I am seeing a hysteresis on my unit that is even tighter than what K-guy is saying that it should be based on my settings.  I wonder if others have seen this or is it just my one unit.
K-Guy
You can change it if you want, the instructions are in the manual. The factory setting are our suggestion on what we think is best.
Nyle Service Dept.
- D. Adams
blackhawk
Quote from: K-Guy on January 07, 2025, 09:04:04 AMYou can change it if you want, the instructions are in the manual. The factory setting are our suggestion on what we think is best.
I have it set at the factory settings, but the problem is that my unit does not function the same as what you told me in reply #23.  From your reply #23, I should be seeing this:
Wet bulb setting = 101F
HyCompressor parameter setting = 1F
Compressor turns on at 103F
Compressor turns off at 101F
But below is what I am seeing:
Compressor turns off at 102F
I am just wanting to understand why my unit turns off the compressor at 102F instead of 101F?
