Firewood processing whole rounds
Started by MrRastos, August 20, 2023, 06:33:19 AM
MrRastos
I've been making a bit of firewood by hand and selling it for a few years now. My customer numbers are growing, but so is my age along with it, so I found a used Hakki 1x37 easy and I'll be processing what I can with it.
A fair amount of customers want some smaller pieces left whole. As an example, one guy has a furnace and wants everything under 6 inches left whole. However, the processor auto cycles. It wants to split everything, even 3 inch sticks. How do I get around that? It would be a pain to separate sizes and still do all the rounds by hand.
LT50G38 Wide, Hakki 1x37 easy, 1994 Kubota M8030, Farma 5.3- T8, Timberjack 225D, Kubota KX080-4 with Arbro 400 stroke head, IH 444 diesel, IH 434 gas, Volvo clunker dump truck, 2003 F550, 562 Husky, 555 Husky, 272 Husky. 261cm arctic Stihl.
GRANITEstateMP
if you 1x37easy is like my old 1x37, and you drop the splitting knife doe to the lowest setting.  That is how you'd change from a 4 way knife to a 6 way, etc.  With the knife in the lowest spot, you simple pull up on the knife and set it aside on logs you don't want split
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
MrRastos
If that's the case then that's a very simple answer. I only just bought the machine. I had no idea the blade was that easy to remove.
cutterboy
To underestimate old men and old machines is the folly of youth. Frank C.
GRANITEstateMP
Easy is key.  put the knife handle all the way down, actually a bit past the last detent
As you can see, the round rod that moves the knife up and down has now come free off the knife. Just pull up on the knife to remove it
I switched between the 4 way a 6 way a few times today. I don't use the 6 way much bet had some just right ash and red oak that it worked great in.  I have done a few cords with no knife, but not many
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
jimbarry
MrRastos
The splitting wedge on my particular machine was not removable until I examined the mechanism and saw that one of the mounting points of a linkage had been misaligned when someone re-welded it. After some modification I was able to make it work properly.
The biggest issue I have now is how quickly the saw chips pile up under the machine. I need some sort of removal device.
Someday I want to build my own machine, but in the meantime I'm hoping to learn a lot about design pros and cons from this machine.
GRANITEstateMP
As to chips, make sure the little square "tunnel" under the saw head stays clean and clear of chips and plugs.  Most chips come off the chain and are shot down the tunnel out the back of the machine.  I catch mine in a 5gallon pail and dump that into an oversized wheel barrow every time it fills.  I have also.placed a couple scrape pieces of 1x6 along the backside of the machine to keep the dust from making its way back under.  I have some 3in (ish) risers under the machine to help keep it off the ground.  I use a grain shovel to clean out under the machine about every cord or two
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
