Author Topic: Future Forestry Products logging arch  (Read 6953 times)
Offline Robert R
« on: May 26, 2005, 09:14:19 PM »
I am in need of a quicker method for moving logs.  I usually have to skid a long ways (the last 2 jobs:  one was a half mile and the other just over a quarter mile).  I skid with horses and they can handle around 300 boardfeet at a time but have to spend a significant amount of time catching their breath.  I got the video from Future Forestry and it looks like the bee's knees--almost to good to be true.  For the same price, I can get a logging cart designed specifically for horse use but I learned earlier this week that I am being dinged at the mill for having dirty logs.  If I can get them completely off the ground, they will stay clean and the girls could move a lot more a lot quicker without all the stopping and blowing.  Does anyone have one of these?  Do they work as slick as the video shows?
chaplain robert
little farm/BIG GOD
Offline Ironwood
    • http://www.branchandburl.com
Re: Future Forestry Products logging arch
« Reply #1 on: May 26, 2005, 09:33:55 PM »
I don't have a horse, but I can't say enough about the Future Forestry product line. I barrowed a friends tractor arch for many months as he built his house and idled his tree business, Great products well engineered and relatively inexpensive given their capacity. I don't think you would be dissatisfied. The "Tractor Arch" would be the minimum size for me, and the girls will like the fact that it is very light.
    Future Forestry should sponser the Forestry Forum!!!! ;D
               REID
Offline Robert R
« Reply #2 on: May 26, 2005, 09:56:01 PM »
I like the size of the tractor arch and the girls could handle one of that size.  Unfortunately, at least with me at the reins, backing them is a bit precarious, especially with a dual-articulating set up like I would have to have.  I would put a small cart behind the horses and hitch the arch to that.  This would give me 2 bendy points to deal with while backing.  In the video, they show the man just picking up the ATV arch and setting it over the logs after he pulls alongside it.  I think they said it weighed 50-some pounds.  Any idea how heavy the tractor arch is?  Could it be lifted by one man over a log rather than backed straddling it?
chaplain robert
little farm/BIG GOD
Offline beenthere
« Reply #3 on: May 26, 2005, 10:52:54 PM »
Rober R
To avoid backing up the cart:
Will the 'girls' come alongside the log, and one step over it?  dragging the cart over the log?
Maybe not if the log is of any size.
Maybe on some logs, the team could walk the full length of the log from the top, with one on each side.  Seems that would only work for the best situations, and where all brush and limbs were knocked down pretty good (but maybe that is necessary anyway).
Offline Robert R
« Reply #4 on: May 26, 2005, 10:57:43 PM »
Those are fantastic suggestions, Beenthere.  I wouldn't have thought of them.  Thank you muchly.  They ought to be able to straddle up to a 30ish inch log if I took their neck yoke off, which just clips onto each horse to keep them from spreading apart.  Up through low 20 inchers, even that wouldn't be a necessity.
chaplain robert
little farm/BIG GOD
Offline Ironwood
« Reply #5 on: May 27, 2005, 12:40:33 AM »
The Tractor Arch, is tongue heavy. I put an adjustable channel style hitch at the front of the one I had fabricated (longest one they make, I think "5 position"). That way you can use a pintle or a standard ball, additionally I use the bottom two holes in the channel to mount a pneumatic wide tire that I welded up a swivel for. It is quick pin removeable and helps with not killing your back, I made mine a little bigger and heavier but the same idea would help with the Future Forestry Tractor Arch as well. Also the swivel and tire enables me to roll it down into a yard and winch the thing back to the truck without getting the truck stuck or damaging the yard as much. These mods. I am sure have been considered by them but due to "price point" consideration may not have been implimented. I have a small metal shop and the mods. to everything keep coming!!!! ???
                         REID
Offline caryr
« Reply #6 on: May 27, 2005, 01:37:59 AM »
Hi Robert,
50 pounds sounds a bit light for the ATV arch, but since I have the fetching/ATV arch combo mine may be a bit heavier than the normal one. The tractor arch is significantly heavier. It's not something most people would be able to lift over a log.
The ATV arch can fully suspend a 12' log the tractor arch can fully suspend at least a 14' log. Here's a picture of a large 20' log fully suspended using both the tractor and fetching arches.
Cary
Offline Woodhog
« Reply #7 on: May 27, 2005, 09:41:07 PM »
You could always try one of these....if you have a decent road to your landing..
you could skid a bunch to a secondary landing in the woods and then load them up and
haul them out nice and clean...
http://www.payeur.com/En/products/Metavic.htm
Clix on horse drawn wagon line......
Ira
  • Guest
« Reply #8 on: May 28, 2005, 01:26:43 PM »
Hi, I haven't been here in a while,I had to reregistar to answer this post :o Robert,are you using any kind of a log cart/arch now?
Offline thedeeredude
  • RufusRuffcut and Sawtooth to da races!
« Reply #9 on: May 28, 2005, 04:40:07 PM »
How about this kind?  Specifically made for horses.
small link
Offline Robert R
« Reply #10 on: May 29, 2005, 05:15:51 PM »
Hi Ira, are you the Ira I think you are, of horse pulling fame?  No, I am not using anything but a chain and tongs right now.  I have looked at the cart from Farmer Brown's Plow Shop.  I like it real well.  Bit I like the idea of the logs being completely suspended and staying clean.  I do have a forecart but I picked it up while delivering my last load of logs, so I have not tried it yet.  If you are the Ira I think you are, I heard somewhere that you sell horse logging carts.  If that is you, where can I get info on it.
chaplain robert
little farm/BIG GOD
« Reply #11 on: May 29, 2005, 09:55:02 PM »
Offline hosslog
  • A bad day in the woods is better than a good day anywhere else
« Reply #12 on: May 29, 2005, 10:10:45 PM »
Robert,Forest Manufacturing sells exactly what you are looking for,log cart with a trailer type arch.They have a catolog, the phone no. is 1-814-653-9695. They are amish so you might have to let it ring.
Offline Robert R
« Reply #13 on: May 29, 2005, 10:22:17 PM »
That is a pretty cool setup, DeerDude.  You must be into horses also to have all these links.  That looks like it would be great to have but I am afraid that I am a little to small time to make that much of an investment reasonable.  Will go on the dream list, though.
chaplain robert
little farm/BIG GOD
« Reply #14 on: May 30, 2005, 02:32:09 PM »
Yep, where I live, horses and mules are just as popular as tractors.  Not only that, I'm researching these things for future issues( :)).  What you could always do is, if you're a welder or know a welder, make up your own DanG trailer and save a few grand.  Something like a wagon gear from an old farm wagon, weld bunks on the side and get some hydraulic cylinders and a small pump and use some overhead lifting tongs to make a loader.  It would be pretty cost effective, maybe $4000 or less.
Offline sawmill_john
« Reply #15 on: June 18, 2005, 02:03:13 AM »
I've known Mark Havel for quite a few years now, his products are well designed and built right, no cutting corners. and they do work just as easy as in the video.  I've used several of the smaller units at logging shows and I'll tell you what if you buy one, they save so much work, you'll kick your self for not getting one sooner!  They almost make your peavey obsolete.  If you have questions call Mark up, he a real nice guy, he hits the show circut to if he's coming out your way he might be able to bring one out and save on shipping.
john
Future Forestry Tractor arch
Started by dutchman on Forestry and Logging
Last post October 20, 2005, 11:16:20 PM
by Ironwood
A pile of scrap or a future logging arch?
Started by jph on Forestry and Logging
Last post April 25, 2008, 07:58:15 PM
by semologger
Future of wood products?
Started by bkellyvtme on Forestry and Logging
Last post February 10, 2007, 07:40:34 PM
by Woodhog
Small Scale Logging Production, Cords/Day w/ ATV, Logging Arch, & Chainsaw
Started by NorthMid on Forestry and Logging
Last post April 12, 2015, 10:15:27 AM
by 101mph
