Struggling to split Cherry Log
Started by DrakeTruber, May 08, 2024, 10:29:56 PM
DrakeTruber
Hey folks, I have black cherry that I am trying to split into a clean slab. Snapped my chalk line, went to the trouble of hammering my hatchet all along the intended split lines before hand, and then split with steel wedges. Everything seemed to be going well until the end of the split, where I found that the grain in the middle had wandered away. I tried on the opposite side of the log and the same incident happened. How can I prevent the grain wandering off like that in the middle? Thanks for your feedback
Don P
The young tree was not perfectly straight, which is normal. The split follows the grain, which was not straight in that young tree. I don't see anything in your pile that would split straight. On the plus side we can suggest a chainsaw mill as labor saving device in this thread  ffcheesy
You can not prevent what is already in the log.
Due to the nature of Cherry, most logs have a natural "pith check".  I see one in the log that you have already split running from about 2 o'clock at the top to about 7 o'clock at the bottom.  There is nothing that you can do with this one that you have already started, but in the future, I would orient any splitting with this pith check.
You are experiencing grain run out by trying to follow a line.  I would not pop a line but start the split on one end and follow through from that end and let the split follow the natural grain of the log.
I also recommend a chainsaw.
doc henderson
looks a bit like work.  Nice job.
DrakeTruber
Thanks for the feedback guys. Is the subtle spiraling of the bark what told you that Don? Magicman, that's interesting advise to just follow the grain.
With a slightly less than perfectly straight grained tree, what would be the old-timey way to remove large amounts of material to get things flat after splitting? An adze or broadax perhaps?
Roger that on the chainsaw
rusticretreater
You probably want either a side axe or a hewing axe.  A side axe has the handle off to one side instead of directly inline with the head of the axe.  This allows you to follow the plane of the surface of the wood without banging your knuckles, etc.  A hewing axe usually has a big bearded blade that is used to true up beams and the like.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Don P
Heck no, nothing subtle, it's cherry  ffcheesy. You don't have a straight stick in the pile and it is known for "not a straight stick in the pile". Funny though, once its dry it was the wood used for typeface because of its stability.
You can hew, broadaxe, adze, jack plane and get there. Or some form of sawing.
If you look at a hewn log cabin you can see the cross grain strikes every few inches down to a certain depth then a broadaxe hews to connect those chops. The cross grain chops keep a long twisting grain from diving too far off plane.
It can be cleaned up or done with any degree of care desired, this is a good bit more finished;
DrakeTruber
Awesome response Don. I never thought about how the crosscut chops prevent the grain diving to deep during the hewing. That must be why the chops are always done slightly deeper than the intended plane?
I have a broadaxe and broad hatchet, both unused. Still need to get them both sharpened and the hatchet bit hung. This is all pretty new and exciting but the hang ups in the learning process are brutal. Ive been learning everything from books, this forum and some Youtube. Been a huge fan of this forum for a while so I'm very grateful to partake of the wisdom shared here. Thanks
Southside
Just out of curiosity what are you making?
White Oak Meadows
DrakeTruber
A japanese Atedai, basically a floor planing/work bench.
maple flats
I sence a chainsaw mill in your future. Good luck!
DrakeTruber
Al_Smith
Most of my decent cherry logs have all been bandsawn,stickered and stacked under cover in my shop .Those unfit for lumber I split with a hydraulic home built splitter ,fire wood .Has a pleasant smell when it burns very festive around holliday time .
However all that said you could use a little 4 inch power planer and level that wedge split example .Wait until it's dry though but it will take a long time to  get it good and flat .
DrakeTruber
Thanks for the feedback Al, more of the Cherrywood has become firewood than I'd like to admit. But I agree, cherry is fun to build fires with.
TreefarmerNN
Quote from: DrakeTruber on May 10, 2024, 09:51:14 PMAwesome response Don. I never thought about how the crosscut chops prevent the grain diving to deep during the hewing. That must be why the chops are always done slightly deeper than the intended plane?
You will want your tools very, very sharp and if you are working so that a miss hit could possibly hit your leg or other anatomy part, make sure you protect yourself.  As you've found, cherry can be very hard and with the grain running off it's easy to have an axe or hatchet slide off and find something softer to hit.  Make sure that "something softer" isn't you.
I like using a jack plane for something like that but again, it needs to be sharp.  My SIL was flattening some walnut with one of my planes and he asked if it was sharpened on a grinding wheel.  I assured him that final edge was done with 600 grit sandpaper on a flat surface.  Even that was a bit coarse for what I prefer but you could easily have shaved with that plane.
