What are you cutting 2024? - pics welcome
Started by Ianab, May 09, 2024, 12:06:13 AM
0 Members and 11 Guests are viewing this topic.
New Thread for pictures and other updates / discussions etc.
Old thread is available here, but is now locked.
https://forestryforum.com/board/index.php?topic=80957.0
Carry on.  ffsmiley
Nealm66
Swinging a big rotten leaner
Nealm66
I'm not sure if I'm loading the pictures the best. I'm using an IPhone and selecting small as the format?
might try medium, at least for pics where detail matters.
Like Doc says, you can go up a size.
The bit that says 240x320 is the number of pixels (dots) in your image. You can go for 640 or 800 and get a larger (more detailed) image, without blowing the file size.
Modern cameras lake crazy big files, default on mine is 4096 pix wide, or about 3 average monitors across, and maybe 5 mb file size. And it's not a high end phone. So there are limits put on the forum file size so Lil can't accidentally upload a 12 mb / 8,000 pixel image from her phone, and waste Jeff's server space  and bandwidth, when it then gets shrunk down at the end screen to ~1,000 pix for display anyway.
So you are doing it right by selecting and uploading the smaller size image, just you can go up a step in size and it will be fine.
Hogdaddy
Ah man.... I hate our old thread has been locked. Glad I was a part of it! And like he said carry on!  I tried to downsize a pic, will have to try to post it tomorrow.  :thumbsup:
If you gonna be a bear, be a Grizzly!
Nealm66
Spring has sprung here in the pnw
Nealm66
Pitch is boiling out on this one. Bark is slipping on the Doug firs ( not a great way to fall)
Hogdaddy
A hickory I cut the other day. Not huge, but a good one. 4 foot at the stump.
https://forestryforum.com/gallery/displayimage.php?pid=353777
Hogdaddy
Hogdaddy
WhitePineJunky
WhitePineJunky
 I know that burn was a personal tragedy for you, but you're making the best out of it. Those are really nice looking skids behind the ol TJ!
WhitePineJunky
Ron Scott
~Ron
cutterboy
WPJ, Great pictures, keep them coming. I really enjoy them.
Old Greenhorn
Just short of a year ago I wrote this in the thread soon after your fire:
June 11, 2023, 12:56:57 PM
WPJ, what I am seeing in that photo looks like a fairly fast moving mid-story burn, some creeping fire on the ground but not a lot, that took out the saplings if there were any and some smaller trees. Look like most of the stuff on the ground may have been litter before the fire? The crowns of the trees are all brown BUT they re there. This tells me that fire was not hot enough up in the crown to do a complete killing burn. This I see as all very good news. Give it time and see what pops. I also see green in the background so perhaps there will be some regen coming from that side also?
 Yes, quite a blow and extremely depressing, but at least you are there to fix it. It will take time for sure. Now would be a good time to clear up all that litter, before the grass pops up and covers it. Miserable and dirty work, but much easier now than later.
 In my experience white pine is quite resilient and grows like weeds. I have a patch 50' from where I sit right now where the saplings are popping up 14" apart and choking each other out. I am considering it a mini nursery ;D.
 Best of luck man. Stay strong, you will get through this.
Now that you are approaching the anniversary I am wondering how you are feeling about the whole incident? You've already put in a lot of work and have a lot more to go, but are you feeling like you have a grip on it? It's too easy for 'other folks' to be sympathetic for a while after a tragedy, but then they move on. You can't move on without dealing with it and I wonder how your are coming along for yourself?
WhitePineJunky
Good question!
I was very devastated after it happened, but i rebounded quickly, and decided I was going to make the best of the situation, fast forward a year and it may be of surprise to many... but I'm glad it happened at this time, the forest will comeback and look much better than it did before, il be there the whole way along to baby the trees, do spacing, species favouring etc.
it's a clean slate and I have the opportunity to really steer the land in the direction I want it to go, when I got to it, a few years ago it was umanaged land with no thinning done, some trees were alright but not the best lumber
After all said and done the land only became more sentimental to me as I have literally stepped over every square foot of it "restoring it"
I have logged off about 50-60 acres and maybe another 20-30 to hit and the rest isn't timber worthy
Old Greenhorn
Good Answer!
 Although some of us looking from the outside in may have thought, once the fire had passed, that perhaps this might work out fine for you in the longest run. Of course at the time, that would have been the least 'sensitive' anyone could have said given what you were looking at and processing right at your feet.
 I am very happy for you that you have come around to this way of thinking and dealing with it. Looks to me like life threw you a truck load of lemons and rather than make a lot of lemonade, you are going to make a fine wine out of them. It will take longer, but has a bigger payoff.
 Onward and Upward!
WhitePineJunky
BargeMonkey
Haven't had much good to say, being home for 2wks off seems weird.
Burn brush, truck wood. Fighting a gremlin in the Timbco, United has a decent Tigercat in Houlton I wanna go look at, little Rowan showing up this time prevented any road trips to look at iron.  Messenger_creation_775f02c4-b0a8-4935-a7ed-98c3b87a8349.jpeg
Move to a local job when I get back, then move to a forester job, I keep telling myself I'm retarded for wanting to cut wood this year. There's a fair amount of big wood on it, my father cut it 40yrs ago, getting the major haircut this time.
newoodguy78
Well congratulations Barge , Mom and baby look like they're doing good hope you are as well.
Nice brush pile burn too by the way.
congratulations Barge and family!
