Post and Beam Build Has Started
Started by Rhodemont, June 09, 2024, 10:43:52 AM
philoufelin
Hi,
First, I wanted to congratulate for the incredible work ! I am wondering how you managed the shrinkage with your beam ? I worked on a smaller projet and faced issue with the shrinkage of my beam. I spent a lot of time to bring back the beam squarre and realised they were still twisted when I was ready to do the joinery. Did you use end grain sealer to prevent shrinkage ?
Quote from: philoufelin on December 19, 2024, 09:01:32 AMHi,
The twisting is possibly identifiable in the log as it relates to spiral grain grown into the tree, and usually identifiable. If observed, then can avoid it in a beam that you do not want to twist when drying occurs.
The width and depth shrinkage in a straight-grain beam still needs to be accounted for when drying happens.
Stephen1
The length will not shrink. Shrinkage is inevitable and such you build that into your sizing or do your joinery quicker.
Rhodemont
Phil,
  First let me thankyou for you complement. Being my own worst critic sometimes it is tough to see the forest through the trees.
I am truly a novice at this, so what I know is from building run-in sheds for my horses and what I have learned on this forum.
Being my own timbers  I bucked them well over length and sealed the ends with Anchor Seal immediately upon cutting to length.  I added a good foot on each end of length to allow for end checking when cut to finish size.  As I posted a while back I sawed them 1/2 inch in width/height oversize to allow for several months of drying shrink.  Every post and beam is pith centered ( or as centered as I could saw) which worked out well as I found very little camber in the components after the aging.  I do wish I had gone a bit more in oversize because just skimming 1/4 inch on each side is not as easy as it sounds because shrink varies with  the grain and knots on the surface.  I did not pay attention to length as I cut them to exact length just before installation.  When I skinned/cut to length and prepped them the linseed/thinner goop went on right away including the ends.  I see no signs of length shrink but checks and width/height shrink is occurring and will until until aged through out which will take several more years.
So, that is what I know.  Hope it helps.
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
philoufelin
Quote from: Stephen1 on December 19, 2024, 02:15:11 PMThe length will not shrink. Shrinkage is inevitable and such you build that into your sizing or do your joinery quicker.
Thank for the answer. I understand the skrinkage is inevitable, so the best strategy is to cut the log and do the joinery quick. Is there any strategy (log sealing, etc.) ?
Rhodemont
I put the linseed goop on right away to seal the ends and surfaces to preserve the fresh finish of the wood.  Once I get the siding on this spring I will need to go over the interior with the sander to shine it up and apply another coating.
Rhodemont
The pic is from where I left off in December the morning after having finished the roof.  Have not done any building since then.  Folks who walk our road have been asking when I am going to start up again.  All I can say is I have been working all along to fell the trees, skid the logs, and saw the timbers needed to continue the build.  I have a few more timbers to saw then start building with the plan for this year to frame the side over the slab for my truck, frame the back shed roof for firewood, frame in all the sides for doors and windows, and get siding and balance of roofing on.   Lot to do.  Oh and still have to saw the rafters for the two roofs.
You have done a lot and still have a lot to do.
Mighty fine Sir,  Mighty Fine.  :thumbsup:
Rhodemont
I have started the building again now that most of the sawing is complete for what I need this year. (still need to saw the rafters).  Girts and door headers are installed on the first level.  Had to raise 7 more floor joists that did not get done last fall.  Interesting issue arose with them.  The joists put up last year have continued to dry causing a 1/8 to 1/4 inch step down from the new joists end but up against them.  Based on this step I decided not to screw these new ones down and will let them try and catch up in the drying shrink before fixing in place. Next will be the girts spanning the columns of the gable ends just below the top of the knee wall.  These will also act as the framing for  the second floor windows to rest.  Sure would be nice to have the scissor lift to raise these.  Instead I plan to raise them as high as I can with the forks on the tractor and then use block and tackle mounted on top plate and center column to finish the lift. Hoping to get on this when the weather settles/warms.
Rhodemont
Next set of post and beams to go up.  I need to slot the ends and drill pin holes where needed, then assemble and raise.  Should have them up Tuesday.
Stephen1
Rhodemont
No, not planed.  I use a new band and skin about 1/4" off each side.  Then hand belt sand with 80 grit paper.  Gives me a real nice finish to then put the boiled linseed/mineral spirits goop on.  I tried a hand planer on some practice beams but it did not work out as well.  Even with the best skinned beam there are some uneven areas particularly where there are knots or checks.  The  hand planer could not deal with that where the sander does.
