LT15/LT15WIDE old style clamp modification
Started by booman, August 25, 2024, 08:40:41 PM
booman
I still like to use the old style clamp on my LT15WIDE sawmill along with the new style clamp.   After a while these clamps wear around the bolt and hole and don't clamp as tightly as when new.  I found that if you drill out the 3/8" bolt hole to 7/16" and put in a 7/16" bolt, it kicks the clamp body away from the board or cant and gives a much better clamp.  See what I have circled in green.
2019 LT15G25WIDE, 2013 LT35HDG25, Stihl MS880 with 59" bar with Alaskan sawmill attachment.  John Deere 5045 tractor with forks, bucket and grapple.  Many chainsaws.
booman
Anyone still use these?   Have you had this problem?   Does anyone here eat grits?
I can only say no to one of your questions.
Machinebuilder
Your old clamps look different from my old clamps.
I have put 2 of the new screw type clamps on my mill and will ocasionally use an old clamp when the new ones aren't in a good spot.
I leave the nut off the bolt so i can easily move it to a different bunk. I have learned that it needs to be well lubricated for the cam to work OK.
Dave, Woodmizer LT15, Husqvarna 460 and Stihl 180, Bobcat 751, David Brown 770, New Holland TN60A
booman
Yes, your clamps go way back but I remember them.   They were on my first LT15 and you are right, they needed lubrication.  And I do leave the nut off of the bolt so it is easily removed if necessary.
booman
Cfarm, which question are you saying no to?   Grits or clamps?   Not sure what grits are.
