accuset 1 ...how to operate?
Started by Wingding, September 08, 2024, 10:21:30 PM
Wingding
Cant seem to find anything on how to operate a older accuset 1 ... Ive tried figuring oit out but getting no where...Plenty Info on ther accuset 2..but its not the same...
There You Go Man-Keep as Cool as you Can-Face Piles of Trials  with Smiles- It riles them to believe you preceive the web they weave-Keep on thinking Free...
rusticretreater
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Wingding
I seem to have a different accuset then the one in the instructions.Mine does not have the 4 orange square buttons under the LCD display.   I would send a photo but cant seem to add one here.. well the photos are 2,5 MB and im only allowed 1000KB    have no idea how to downsize... Thank you for trying though.. must have some odd ball tweener accuset.... th simpleset looks different so not sure what I got.....
Wingding
Ok,,,This Old Dog learned a new trick.... Here is two photos of what I got...
terrifictimbersllc
Looks like pre-Accuset 1 to me, both Accuset 1 and 2 have an additional row of 4 buttons directly below the LCD screen and say "Accuset" or Accuset 2 on them.
jaciausa
Mine had an accuset on it when I bought it. I will have to look it up and see what it was.
Woodmizer probably could supply a manual!!
if its all hooked up to saw, just experimenting with it will teach you a lot. Good luck
What I am seeing appears to not be Accuset but Setworks which was Wood-Mizer's first setworks and predated Accuset.  I can't tell from your picture but does it actually say; "Accuset" or "Setworks"?
This is a picture of mine and it is no longer supported nor are there any replacement parts available.  If/when it dies you have the option of installing Accuset2 or Mikron LINK which is not a Wood-Mizer product.  I am sure that Mikron will be my option if/when my Setworks dies.
Wingding
MagicMan,
                  You are correct ... Its a setworks..... It turned on but I cant seem to...energize it... {get it to start cutting at set incriments...
I can not find a Setworks PDF under their Customer Support Resources.  Call them and see if one is available.
There may be someone in tech support that can help you and lead you in the right direction.
I have the Setworks Manual and can make a copy of the programing, automatic mode, operation, calibration, maintenance/trouble shooting pages.  It is quite extensive which is why you need to try Wood-Mizer tech support first.
Wingding
Ok... I figured out how to use it..and it works!!!
I guess I will need to replace it wjhen it goes out with a newer version... Thank you Magicman ..it was indeed a pre- Accuset 1...
barbender
Yep, the original Setworks. I miss mine.
I will not saw without a setworks.  I will replace mine if/when it fails probably with a Mikron.
Ben Cut-wright
Quote from: Wingding on September 11, 2024, 09:47:29 AMOk... I figured out how to use it..and it works!!!
Happy to hear it works. What did you "figure out"?
