Best chainsaw bar and chain?
Started by future_vision, October 26, 2024, 10:28:58 AM
future_vision
I've got a Husky Rancher 460 and noticed that I have a bent bar. I went ahead and  ordered a replacement 24" off Amazon without reading the description. Even though it came up as the top listing for "Rancher 460 chainsaw bar" it is actually for the pro series. Unfortunately, I am passed the 30 day return. Since I am pretty sure I can't convince my wife that I need to buy a professional chainsaw to fit the bar my other option is to just buy the correct bar. The saw came with a 24" and I was going to replace with a 24" especially since I have a few good chains left. I was also going to play it safe and stick with the Husky brand. Here are my questions.
  • Should I stick with Husky brand or is there a better brand. I've seen a lot of Oregon bars on pro saws.
  • Do I stick with a  24" bar? I've ready I'd get more out of a 20" bar. Again, which brand?
  • And for chains. What is recommended? I've got mostly pine but a decent amount of Oak, some birch, maple and beech.
scsmith42
I run Stihl's, but have had about equal performance from Oregon brand bars and chains.
Baileys sells Oregon as well as their house brand, and its pretty good.
Tom's 3638D Baker band mill
TreefarmerNN
Make sure you match up the pitch and thickness or you will need a new sprocket as well as bar and chain.
Oregon stuff is good.  Maybe not quite as good as Husky or Stihl but very, very close and there might be a price difference.
barbender
Just because it is a "pro" bar doesn't mean it won't work for your 460 rancher. You need to know some specifics.
Bars and chains can be very confusing. There are lots of different specifications, and some of them overlap but aren't cross compatible, with no real reason for the difference. I'll try and explain better.
 Your 460 runs a 3/8" pitch chain system I think (I'm not overly familiar with that model). So when you buy a bar, you need a Husky large mount (small mount would be .325 pitch) 3/8 pitch. Now in 3/8 pitch, you can have .50, .58, and .63 gauge, which is the thickness of the drive links and corresponding groove in the guide bar. You can run any of the three, but the BAR AND CHAIN have to match!
 The different gauges add a needless level of confusion to an already confusing situation IMO.
 The drive sprocket on your saw will be set up for 3/8 chain, the gauge doesn't matter to the sprocket. I would suggest using whatever gauge is most common in your region- for me, that's. 058".
 Anyways, as far as what I know, if the 24" bar you ordered fits a 562xp or 572xp pro saw, it should also fit your 460 farm/ranch saw as they share the same mount.
 Husky and Oregon chain are both good, Stihl chain is harder and holds an edge longer. It is also much more expensive around here.
Machinebuilder
I also have a 460 rancher.
I have both the 24" bar and a 20" bar. I use the 24" when I need the lenghth but prefer to use the 20".
I got the 460 after i had an accident and crushed my 465. I then found out the bar mounts are different.
I buy this stuff at my local coop so I can't tell you the difference from memory. I also buy Stihl chains there when they are on sale.
I believe Baileys has a good bar ID guide.
Dave, Woodmizer LT15, Husqvarna 460 and Stihl 180, Bobcat 751, David Brown 770, New Holland TN60A
future_vision
Quote from: barbender on October 27, 2024, 12:27:20 AMJust because it is a "pro" bar doesn't mean it won't work for your 460 rancher. You need to know some specifics.
Unfortunately, the bar doesn't fit. The tensioner hole is offset more. It's odd because if you do a bar search on Husky's site it comes up as one that should fit. Pretty bad when you can't trust the manufacturer's site.
future_vision
Quote from: Machinebuilder on October 27, 2024, 08:09:35 AMI also have a 460 rancher.
Yeah. That have a basic Husky bar that is specifically for the Rancher at my local Tractor Supply. As hard as a tried I could not find an identical Husky bar that matches the one I had. The one I had had the replaceable sprocket. I'm guessing they don't make it anymore.
I am definitely interested in dropping down to a 20" bar. Problem is I've got 3-4 24" chains and don't really have the resources, at the moment, to get a 20" and chains.
TreefarmerNN
Any saw shop should be able to shorten your existing chains.  It's just taking out two rivets and putting one back on each chain.  If they make up chains from bulk chain, they will have a rivet spinner and rivets.
barbender
Hmm. That's good to know, and sorry if I'm giving bad info- I thought thought that Husky only used two different mounts. Small mount at .325 and large at 3/8".
John Mc
Quote from: barbender on October 31, 2024, 08:24:10 PMHmm. That's good to know, and sorry if I'm giving bad info- I thought thought that Husky only used two different mounts. Small mount at .325 and large at 3/8".
I thought the small mount and large mount bar styles were independent of the chain pitch.
I have a Husqvarna 357 XP which takes a small mount bar (Oregon K095). My Husqvarna 562XP takes a large mount bar (Oregon D009). Both run 3/8" chain.
barbender
I'm learning with every post, John!👍
caveman
Our 359, and 545's use the small bar and the 365, 572's and 3120 use the large bar mounts.  We use .325 on the 545's and 3/8, .050 on the others (3120 uses .404).  So, on a 20" bar, the same chain can be used on the 359,365 and the 572's.
Caveman
Big_eddy
Quote from: future_vision on October 31, 2024, 02:43:07 PMUnfortunately, the bar doesn't fit. The tensioner hole is offset more. It's odd because if you do a bar search on Husky's site it comes up as one that should fit. Pretty bad when you can't trust the manufacturer's site.
Still uncertain what the issue is. Husqvarna really only uses two basic bar mount profiles, with different gauges and lengths and sprocket pitch. The mount profiles define the size of the studs (stud slot) the location of the oiler slots, and the size and distance from the center line of the tensioner holes. The tensioner holes may be different distances forward and back, depending on the profile of the bar. As long as they are the same distance from the centre line of the bar, it will fit.
Mount type is not directly tied to chain pitch, but smaller saws tend to use both small mounts and 0.325 pitch chain. The cutoff for both seems to be in the 55-60cc saw class. (For instance, IIRC, the 560 sold with a small mount bar and 0.325" chain and the 562 uses a large mount with 3/8". The saws are essentially the same otherwise)
Pictures of your bar tails might help.
Machinebuilder
I haven't taken the 24" bar off my saw a Husqvarna 460 Rancher.
Here is a pic of my 20" bar with the p/n and holes
I hope this helps
Big_eddy
Two different Husqvarna 18" large mount bars.  Note the difference in tensioner hole locations.
Both work as expected on both of my large mount saws
Machinebuilder
Quote from: future_vision on October 26, 2024, 10:28:58 AMI've got a Husky Rancher 460 and noticed that I have a bent bar. I went ahead and  ordered a replacement 24" off Amazon without reading the description. Even though it came up as the top listing for "Rancher 460 chainsaw bar" it is actually for the pro series. Unfortunately, I am passed the 30 day return. Since I am pretty sure I can't convince my wife that I need to buy a professional chainsaw to fit the bar my other option is to just buy the correct bar. The saw came with a 24" and I was going to replace with a 24" especially since I have a few good chains left. I was also going to play it safe and stick with the Husky brand. Here are my questions.
I am posting this to put all info in one post.
These are the bars and chains I use on my Husqvarna 460 Rancher
24" bar
24" chain
20" bar
20" chain
I buy my saws, bars and chains at my local coop.
I don't know enough to try to match things up correctly if i buy them from somewhere else.
I use the same type of chain.
What I like about it, I can hit something and get it back in just about one sharpening.
I posted a few days ago in the , Did Something Dumb, thread.
I hit a round piece of steel I use to separate my logs and to dig rocks.
I put the saw on the ground and sharpened it and it was pulling into the wood.
If that was a Oregon chain it would take me about 3-4 times to get it "back". Then by that time I have hit something else and it starts all over again.
I work in a auto parts store and we sell orogen chains. I could probably but them for half what I buy a stihl chain for.
I am claiming back old pasture land and I cut my stumps just about into the dirt.
I get a lot of practice with hitting stuff.  :wacky:
David B
Small mount is K095 mount. Large is D009. They both can be had in different gauges (corresponding to drive link thickness). The small mounts tend to be .325" pitch and the large .375"....but that is dependent on the  sprocket pitch in the bar tip and the saw's drive sprocket.
I'd recommend a k095 Oregon versacut bar in 3/8"  pitch and stihl chain.
- davidwyby
Machine and welding shop day job, trees after work.
