Eaton winch brake slipping on 230TJ
Started by Mountain_d, Yesterday at 07:57:43 PM
Mountain_d
I was hoping some members can help me out. I have a 1978 TJ230 with Eaton winch. The brake is not holding the load up as it should. It was slipping a few months back and I adjusted the two jam nuts on the cylinder and that helped but it is slipping again. My bottom nut only has about 2/3 of the nut threads still on the bolt and the top nut is snugged up so I figure I am out of adjustment. I thought the break banks were worn but I can see through the inspection hole in the winch guard that I have about 3/8 inch of friction material on the band. Could it be that my spring inside the winch cylinder is weak? How likely is that? Can anyone suggest other likely causes?
Thank you all.
Mountain D
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Mountain_d
I can also add that there is no oil leaks so the slip is not caused by oil on the friction material. I believe it is the spring inside the cylinder that holds the load up and when the hydraulic piston is pressurized it overrides the spring and allows the load to drop. Is that correct?
Mountain D
fluidpowerpro
Might want to check the drain line from the brake. If for some reason your back pressure went up the brake will be partially released.
Change is hard....
Local wind direction is determined by how I park my mill.
