Spring is here! Started up the LT35HD for the first time
Started by DanMc, Yesterday at 04:07:27 PM
DanMc and 2 Guests are viewing this topic.
DanMc
After weeks of the deep freeze, things are warming up here in MA and we have our first day that's almost 70 degrees.  I took the cover off the mill head and the engine came to life on the first crank.  What a happy sound!
Quick question:  Is there an easy was to make sure that there's not a mouse nest inside the flywheel housing, that could plug up the engine's cooling fins?  Last spring when I fired it up after winter, I saw some grass and little bits of junk coming out of the engine, but I ignored that and got to work.  This year there was no debris flying out, but now I feel guilty and maybe I should be more careful to check.
It's probably safest to remove the flywheel shroud and get a good look, but maybe there's an inspection port somewhere?
LT35HDG25
JD 4600, JD2210, JD332 tractors.
28 acres of trees, Still have all 10 fingers.
Jesus is Lord.
240b
i too started the mill today after 4 months!
   last year it chopped up the mice and sent them out the back
  there is still a leg caught by the spark plug  it was 65° it felt like 90
Resonator
I've got a 19hp Kohler on my LT28, and l leave the cover off the flywheel. I had a major mouse-house mess inside it a couple years ago, and since leaving it off they haven't been back. I periodically check inside the air cleaner cover, the air filter, and anywhere else around the engine for intruders that got in.
Have had birds in early summer try building nests inside the blade enclosure too. I stuff rags in the openings around the blade if it sits idle for weeks to prevent this.
Independent Gig Musician and Sawmill Man
Live music act of Sawing Project '23 & '24, and Pig Roast '19, '21, & '24
Featured in the soundtrack of the "Out of the Woods" YouTube video:
"Epic 30ft Long Monster Cypress and Oak Log! Freehand Sawing"
