Equipment and methods for Harvesting eastern red cedar
Started by Log321, April 02, 2025, 01:44:11 PM
Log321
Hey guys I made a post awhile back about markets for erc, I've cut an acre out of 100 or more that I own with a chain saw and it produced enough that it's definitely worth logging the rest. Now my question is what would you guys recommend for equipment to take some labor away? I have a skid steer and grapple that i used to log the acre. Still a lot of hours and labor in it so I was wondering if anyone had a better way. I know a harvester and forwarder would be the ideal setup. But don't have that kind of money to spend right now. Open to suggestions. Cedarman do you have any input? Thought about a feller buncher attachment for skid steer but that doesn't solve the limbing aspect. Thanks guys
doc henderson
I am a small hobby operation.  I have a track loader and 32-foot gooseneck with @yellowhamer log bunks.  I find the hardest thing is to limb them after falling.  I have a Stihl pole saw and I limb as far as I can up the tree and clear the limbs before I fell it and buck it.
doc henderson
there was a video about an old wheel made to pull the tree through and limb it.  there are also hydraulic ones that run up the tree to delimb.
doc henderson
barbender
I went to NE Nebraska 4 years ago Iirc, with a cut to length forestry equipment manufacturer to do a demo cutting ERC. It reminded me of doing a first entry white spruce thinning up here. Lots of limbs.
It would be miserable stuff to hand cut, I think. Those limbs, while brittle, are very stiff and I would think they would be miserable to get through to get to the base of the tree.
Take a look at "The Stripper" delimber. It is a pull through delimber, I thought about building a smaller version to use with my skid steer. If you used one in conjunction with a forestry grapple for a skid steer (like a log loader grapple, not the run of the mill brush grapple) it would be pretty slick.
I have one I built for my skid steer years back, and I've moved a ton of wood with it over the years. If you're working roadside, it's actually a pretty efficient method for moving small to medium sized wood (which ERC is).
doc henderson
I limb the lower 12 feet and then cut it down.  the pole saw keeps you on the outside.  a teenage kid to grab limbs out of the way as you work around the tree is helpful too. :wink_2:
Cedarman
When I first started logging cedar 40 years ago, I used a medium sized chain saw to directionally fell the tree.  Then used a technique of letting the tree carry most of the weight of the saw at times as I delimbed. I would limb up to about the 4" diameter and clip off.  Keep saw sharp.  You can use an 8 sprocket rather than a 7 to speed chain up. I used a 60 HP tractor with Farmi winch to yard the trees. Made a stick of proper length and used marking paint to mark where to cut.  Buck the trees and use a loader to load and go home.  A good day was 30  6"DBH to 14"DBH.  Most trees had 3 to 6  8' logs in them.  Later I used a skid steer with a tree terminator shear to cut and lay down the trees side by side to make it easier to winch out.  The shear has grapples to hold the tree.
Now we use shear on smaller trees, chainsaw on bigger and use a grapple skidder to move to yard and then knuckleboom with pull through delimber and haul tree length to mill where we merchandise the logs to the lengths to fill orders.
Not much help.  Just lots of work without big equiipment.
Cedarman
One thing I forgot to mention.  To cut the limbs off the bottom, leave a 2 foot limb sticking up when delimbing the sides and top.  After topping, take the 2 foot staub and use it to roll the log sideways exposing the limbs on the bottom.  Clip them off and on to the next tree.
barbender
Even with a state of the art, $1.2 million cut to length team, we were cutting about 25 cords in an 8 hour day. It was a demo so we were stopping, answering questions and such. But that doesn't change the fact that it is a low production wood.
To make matters more difficult, the site was in breaks on the Missouri River, so the terrain was pretty steep.
Any harvesting that had taken place prior to us, was either guys with a chainsaw and hand loading posts into a pickup, or some had a tractor and Bobcat.
Or, the trees were harvested with shears, or dozers and pushed into piles and burned. They were being addressed as an invasive species- the guys we were demoing for wanted to find ways to make some profit off of the wood that was being removed.
That said, although the production was very low by our standards, the guys that had been harvesting the cedar were pretty amazed that that much could be piled up in a day😊
Cedarman
One hardwood logging outfit got into a large tract of cedar and harvested it with a feller buncher, grapple skidder, KB with pull through delimber.  They were bringing in about 20 to 22 tons every 2 hours of tree length.  logged to about 4" top.
We buy by the ton.
Got a call yesterday to look at 100 acres of cedar. The forester said it was old cedar and not too hilly.  Will look at it in a couple weeks.  Wants the land given a haircut to let hardwood regenerate.
doc henderson
I got a few trees that had been cleared for houses.  they were piled in a big stack and burned.  the limbs were gone or just stubs, and the wood was fine about and eighth of an inch under char.
g_man
I know nothing about harvesting cedar. I saw this delimber/buncher ?? a while back and thought it was interesting. Could not find a price though.
gg
barbender
Europe has really cool small scale, often ag tractor based harvesting equipment. The problem is trying to get it over here.
chep
G man that is a cool machine! but for the love of it all put a guard in front of the operator.  I thought euros were heavy on safety cops
barbender
Yeah standing in front of that chain is a big no-no!
teakwood
Quote from: chep on April 04, 2025, 02:27:26 PMG man that is a cool machine! but for the love of it all put a guard in front of the operator.  I thought euros were heavy on safety cops
that depends on where in Europe!! central and north yes, east and southeast not so much
