Husqvarna 285 Quit, So was FIRST
Started by weimedog, April 24, 2025, 01:06:31 AM
weimedog
On my list of saws to fix as I re-engage with the saw world.
https://www.youtube.com/watch?v=Zo28xZGLCIg
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
weimedog
weimedog
A preview of me FINALLY understanding why my 285 ran as it did :)
https://www.youtube.com/shorts/Yqp3TZtxeqg
DHansen
Walt, when you pulled the carburetor off the insulator block, did you check for loose bolts that secure the insulator block to the head?  I have that style of carburetor mount on a 162SE and have found them to vibrate loose yet the carburetor prevents them from turning out more than a turn or two. I have been thinking about using some blue lock tight on those two bolts.  I do not have enough experience with that design to know if it is a common problem or not.   Is that brass plug you removed the governor?
