Stihl Woes
Started by ChainBoy, May 12, 2025, 11:00:41 AM
leeroyjd and 2 Guests are viewing this topic.
ChainBoy
Hi Gang,
Though this is the first time I'm posting to this Forum, I've visited it frequently in the past and got some good info from it. So I thought it might be time to post about my Stihl experience and ask for some advice.
Building a log cabin and bought a Stihl MS 251C. Saw did a great job, used it for a year and took it to Santa Fe Power Equipment in NM for service even though it was running just fine. They told me that the piston was shared and that's because I ran it on straight fuel without oil, that this is not a warranty service, and that the repair would cost just about as much as a new saw. Thing is, I never ran it on straight fuel and even showed them a picture of how I cut one of the oil bottles down to the proper fill line for 1 gallon of gas. Made no difference, they just ignored me and told me that Stihl taught them that the only way a piston can get shared is due to no or improper fuel mixture. They showed me how they removed the muffler and how the piston was shared as proof. Later on they sent me pictures of what they claimed to be further proof, problem being those were pictures of a different saw and I sent them the same pictures of my saw while pointing out the clear differences...made no difference to them. At that point I started to research this, came across this forum and learned a lot.
In talking to Stihl directly I was told that there are dealer horror stories and that I should take it to another one. Took it to Albuquerque's Power Generation Service. They told me that the unit overheated and they actually went through Stihl's 20-some point checks to figure this out instead of just pulling the muffler. Stihl approved the warranty because I argued that since the manual doesn't explain how to avoid overheating I had nothing to go by to prevent that. Stihl approved the warranty and only after 3 weeks did I hear from Power Generation Service that I'm getting a new unit. Here's what happened next:
1. They didn't give me a full refund for the diagnostic service which they need to for warranty.
2. They told me that's because the bank charged for the credit card service. Called the bank, they told me that's not true, and the bank refunded me the rest.
3. They wouldn't let me leave until I started the saw. The fuel bulb didn't take on any fuel, even after 50-so pumps. Yes, there was about half a tank of fuel in the tank.
4. Gave up, handed it to one of the guys, he EVENTUALLY got it started but yanked on the starting cord like a maniac even though this saw has an Easy2Start system that only requires a brief, short pull that stores energy and then the engine starts after the energy is released. It's pretty cool, worked great on my original saw, but not this one. So I'm thinking he's ruining the starting mechanism.
4. Once it starts he runs it on full throttle for about 15 seconds, lets it idle for about 3, repeat many times...Told him he's violating Stihl's manual for a "factory new" saw. As if it matters, he goes: "I've been a dealer for a long time."
5. Oh yeah...they wouldn't let me use the restroom regardless of my pleading.
So after only using 4 tanks of gas...chain tensioner doesn't keep chain at proper tightness and it ends up dangling by a couple of inches after a few cuts, there's intermittent rattling from the chain sprocket/gear area when it idles, fuel pump bulb only takes on gas with a full tank, chain spins wildly in idle and no adjustment to the proper screw stops that, hard to start regardless of whether it's cold or has been running, and engaging the chain brake stalls the engine. Add to that horizontal lines I found on the piston after removing the muffler and scratches and other markings on the cylinder housing and it became clear that this saw was definitely not new.
Contacted the Stihl rep for my area and now they want to get the original saw back from Power Generation Service to check it out themselves. Now I'm just waiting.
So here's my question to you guys. Though the original saw did a good job and I'm not willing to write off the Stihl brand quite yet, have any of you experienced anything similar? Do Stihl dealers tend to be that incompetent? Or is that just in New Mexico? Any New Mexicans part of this forum? If so, what dealer did you have a competent experience with?
I'll follow up with y'all once I hear back from Stihl and learn where they want to go with this.
Think you mean to type "scored" for the piston, instead of shared. But we know what you meant.
Pics would help, taken with the muffler removed to see the piston.
was all the bad experience with the two saws with the one dealer?  I have had only two dealers, and they have been great.  the trouble is just like other name brand quality companies like JD and Stihl; they are going for more homeowner business.  I hope the company gets it fixed and can send you a good saw.  sounds like if you are correct, I would be dropping that 1rst dealer.  I would only deal with the second one if they were not the one revving the engine.  Heck if the first was running ok, the have seen normal wear and were making it out as bad.  Hoping to sell another saw or because they are improperly trained.  It may have been fine and still running.  I have all Stihl stuff and a good dealer.  All of the diagnostic costs should be sent to the company or eaten by the dealer.
ChainBoy
beenthere: Well, glad you know what I meant. And honestly, I've seen it mentioned both ways...so I'm just confused...
So the piston was definitely scored. That was not in question. However, you can't just take the muffler off, see that the piston is scored, and conclude that it's due to running straight fuel. You actually have to go through all of the Stihl tests, which includes looking at the entirety of the piston, to draw a conclusion as to what may have caused the scoring. And remember, I NEVER ran that saw on straight fuel...not even improper fuel such as too low in octane. So right from the start I knew those guys didn't know what they were talking about. But what I had to say made no difference...though the Stihl rep I eventually ended up with did pretty well and worked with me.
doc henderson: I took the original saw to that first dealer and then to the second dealer. The second dealer is the one that didn't want to repair it and gave me a "new" one instead. It's that second saw that ended up being revved, improperly started, etc. So now Stihl requested the original saw back from that second dealer to check it out. No mention as of yet what they'll want to do with the second one that's just junk.
so, which dealer was inappropriately revving the replacement poss. used saw?  I assume the second one. You should also check with someone about the replacement saw as the serial number are typically kept close tabs on, so if it was sold and returned, the rep should be able to see it.
Al_Smith
Could this be the ever present oil wars ?Suggesting with regards to certain brands that should only use that brands version of mix oil at it's suggested ratio and only purchased at that dealership  ? Plus if it needs attention only that dealership should do the work  .-----I smell a fish and it's a dead carp .
Al
No such thing as Oil War, only in your imagination.   ffcheesy ffcheesy ffcheesy
Al_Smith
I happen to have a very vivid imagination some times in technicolor . ffcool
TreefarmerNN
LOL, if a saw is running well I would never take it to a repair shop or dealer.  Unfortunately, the quality of our local dealers has declined over time. They used to be Mom and Pop stores and the owners and few employees were there a long time and knew the product really well.  That was a strength of Stihl- if you sold their product you had to be able to service it.
Now some stores are selling Stihl that never serviced anything before.  And their employees come and go and really aren't service techs.  Maybe they went to a seminar for a day or two but haven't any real experience.  Even though I'm not a real mechanic, I'll take a saw apart and look for a problem rather than take it to a shop.  By the time I pay for a couple of hours of shop time, I've probably paid for a start on a new saw if I can't fix an old one.  That reminds me.  I've got a really old Husky that I couldn't get a reasonably priced coil for.  I think those are now available after market.  Time to dig it out of the shed and get it going again.
ChainBoy
Yeah, Doc H., it's the second one. It's in the hands of Stihl now and they have the "new" replacement saw's SN. We'll see.
I don't disagree about the dealer/repair analysis. I had to learn that the hard way. I'm a pretty handy guy and do most of my vehicle repairs myself, along with a bunch of other stuff. But I had work to do on the ranch and since the original saw was working fine, I thought I'd drop it off for service while I continue with my other work. I mean...what could possibly go wrong???
Yeah, well...
