How long can I span with a white oak 6x12 (for a foot bridge)
Started by burdman_22, June 12, 2025, 10:05:22 PM
burdman_22
Im wanting to build a pretty simple foot bridge with a couple of loooooong beams. I need to span about 50 feet. Can white oak 6x12s span this and still support the weight?
I assume even if there is SOME sag it's ok, since it is just a foot bridge...I think we'll just be covering it in planks and putting a railing. Can make the beams for the span a little larger if needed.
Thanks for any tips/advice.
I do not know the math, but maybe the railing can be trussed and offer some rigidity, so it is not bouncing up and down with every step.
chep
Why mill them into beams? Just skim flatten the tops and put decking on leaving them almost complete. That will retain the most strength.  Whether or not it is strong enough to span 50 ft I don't know, but certainly stronger then the stated beam
Rhodemont
I like Chep's idea.
You can mill 50 feet?  If so 6 x 12 is small.  How high above ground/water will you be?  A couple PT posts drive in along side and screwed to your  beams will add a lot.
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
Stephen1
I think Doc has the best idea and that you use your railings to create a truss system that  will help support the beam
Is it over water?  You can span that but if there is dirt along the way, some pilons will also stiffen the beams.  At camp we made one 36 feet and put pilons set in concrete in the middle as is only saw much water after a rain, but the ground was muddy.  6 feet wide and can drive 4 wheelers across it.
Stephen1
Rhodemont
Thanks, but it is also not that hard.  we made RR tie footing at each end.  we tied it in with ties going out to fill with granite gravel for the approach.  added tele poles.  one we had was short, so you see and extra footing part way in on the left.  used brown treated lumber and at regular intervals we had a long 2 x 6 to stick out and support the railing.  there is a stabilizing support in the middle.
scsmith42
For a spam that Long and White Oak I would want a cross-section that was greater than 12 inches. Perhaps 16 or 18 with a 6 inch width.
Tom's 3638D Baker band mill
gspren
When we built a foot bridge at our hunting camp we couldn't drive within 150 feet of it and we used 2 electric poles for the main supports. They were probably a bit less than 50 feet but not a lot less, so ropes, pulleys and grunting got the poles drug down and in place. Used PT 2x6 3 ft long for the deck.
