Hello. 1st post here.
Started by Mgeez, June 21, 2025, 07:56:44 AM
Mgeez
Good morning. This is my 1st post here. Been lurking guite some time. I installed a Mechmaxx 32. Love it so far. I am "trying to cut the beams required for my sawmill enclosure shed.  A Huge learning curve ahead for me. I am on my 4th blade, nails, 2 rear bunker uprights hit, one that I just don't know why it dulled , maybe dirt. Oh well.......learning curve.
I am only focusing on trying to cut 6 x 6  white oak beams right now. I accept all my mistakes so far , but how in the world do you guys cut beams that don't bow?
1st tree was 14'. Straight, but kinda knarly lookin inside. Bowed both ways. So i chose a dead one that had excellent interior wood. Super straight. Cut 2 14' sections. Beams bowed mainly 1 way. Chose best straightest tree in the section i am cutting. 23' white oak again. Healthy as could be. Goal was to cut 3 3 x 8's. All bowed.
What am i doing wrong?
customsawyer
If you can post some pictures it will help us to help you.
www.thecustomsawyer.com
Rhodemont
I had some nice straight white oak logs bow on me last month.  We discussed it  on a thread "White Oak Stress".
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
Mgeez
Old Greenhorn
Welcome to the forum! If you have done any extensive reading here, you know that Customsawyer and many others know an awful lot about your issue. As He said, add some pictures, that will help get you a solid answer. Speaking for myself, what I would want to see is the logs before you cut, and the end grain on the timber after milling. Almost all logs have stress and you have to mill the log to either contain that stress in a balanced way, or eliminate it from your milled product. Where you take the lumber from in the log has a lot to do with this. How large are your logs? That will tell us your options also.
With a little more info the smart guys will chime in with useful knowledge.
Mgeez
I am already frustrated. I have no clue how to navigate this forum to find out how to forward pics.
Put your pics in your gallery, and then link to them in  your post.
Tutorial found in the Index page, and linked to here.
https://forestryforum.com/board/index.php?topic=100194.0
scsmith42
What part of the country are you in? The reason I ask is that if you're near an existing form member they may be able to stop by and give you some pointers.
Regarding milling, and especially Oak, a lot of trees grow with a stress in the sapwood. Because of that for long straight beans the general recommendation is that they be milled from logs that have the pith centred on both ends.
You want to set the log up on your Sawmill so that you are milling parallel to the pith on all faces.  And, you want the same distance from the pith to the outside of your finished beams.
So let's say you're milling six by tens. In the 6 inch dimension, the pith should be centred 3 inches from each side. And the 10 inch dimension it should also be centred 5 inches from each side. And that is measured at each end of the lag.
May Sawmills have what's called a toe board which lets you raise and lower either end of the log so that you can mill parallel to the pith.
Whenever I'm milling large, long beams such as for timber frame applications, I will generally mill an oversized beam and keep turning it until I'm able to mill all of the stress out of the final piece. Usually this means that I'm mailing a couple inches oversized on all dimensions, studying the beam on the Sawmill to see where it's moved and finish it up accordingly.
There is a tremendous amount of information in the archives here about Wood movement. It just takes practice and time to understand how to read a log and select the best logs for your application. Not all species move the same nor do all logs move the same.
But there is no better resource available, anywhere, than the forestry forum when it comes to obtaining quality information regarding milling and drying.
Best of success to you
SCOTT
Tom's 3638D Baker band mill
