Ideas sought - most efficient way to produce consistent length boards
Started by scsmith42, Yesterday at 09:38:55 AM
longtime lurker and 1 Guest are viewing this topic.
scsmith42
So a local business has reached out to me with a request to provide an ongoing supply of 2x4's for their shipping needs.
These will be a one time use, southern yellow pine, and the numbers are very good.  They go through them so quickly that they don't need to be dried or even stickered.  Initial estimate is 300 pcs / week.
I'm excited for the opportunity to have a strong, weekly revenue source, and am trying to figure out the most efficient way to produce them.
Here is the rub - they have to be 99-3/4" - plus or minus no more than 1/2".  Some bow / crook is acceptable.
I have jump saws set up in the shop, and can set up a stop, etc, but that means that I'm having to trim every single board - adding a lot of time and labor cost to the operation.  I could rig something on the outfeed roller tables from the sawmill to do the same thing, but would still have the problem of having to trim each board one at a time.
What I'd like to explore is to come up with a way to precisely cut logs to length before milling, so that every board coming off of the mill is the right length and can go straight into the stack for delivery with no additional handling.  Whatever I come up with has to be pretty precise though.
From a production standpoint, I'm hoping to use 16" - 24" diameter logs, or thereabouts, so that production volume is high.
I don't think that I can eyeball a chainsaw cut precisely enough, so I'm wondering about building a fixture to set a log into and then have some guide arms that a chainsaw bar would clamp into for making the cuts.  I would mark the log position in the fixture so that it could be aligned on the mill to make my opening face and second cuts perpendicular to the end cuts.  I'd want to design it so that I could use a loader to place and retrieve the logs, and take no more than a few minutes to do the end trims and R&R the log.  Ideally I'd trim enough logs in advance so that they could cycle through the mill quickly.
Another option would be to square the log into a cant on the mill, and then use some type of guide off of the mill rails to guide a chainsaw, but this seems to me that it would be slower and more risky in terms of a metal strike with the chainsaw.
What I'm looking for are ideas of how y'all would precisely cut a log to 99-3/4" length before milling, so that your boards were all within 3/4" or so of being the exact same length.
Thanks in advance.
Scott
Tom's 3638D Baker band mill
I could visualize a trough located on the log deck for the log to roll into and a chainsaw arrangement similar to what those firewood guys use.  The trough could pivot at the V so that the log could roll into and out of the other side.    smiley_headscratch
Bert
I feel the answer is to trim the lumber packs to exact length, not the log. A Holtec saw is designed for exactly that purpose.
Saw you tomorrow!
Resonator
One suggestion would be to contract a logger with a CTL processor, to cut some logs exactly to length.
Do the cut 2x4 ends have to be square? That be the disadvantage chainsaw cut log ends, would be less likely to give consistent square ends on all the boards.
Depending how much tooling/set up you'd want to do, you could automate the cutoff process. I know in window and door factories, they will have 2 miter saws set up a set distance apart. A piece of stock will slide on the table between them, be clamped in the center, and the 2 saws will come up from underneath, and cut the piece exactly to length.
TreefarmerNN
I'd be tempted to set up a frame for the 2 x 4's to go onto in a single wide layer.  Have a stop at one end and two moveable guides to run a saw down.  Lay 8-10 boards down, cut the end next to the stop trimming only the barest amount necessary to square the ends.  Clear the cut ends (or have a trough so they would drop through, push boards back against the stop and cut the other end to length.  Use pallet forks to move the layer to your bundle.
If you have an off bearer, set up two frames so one is being cut while the other is being filled from the sawmill.
Ron Wenrich
I've seen carts that they use to stack lumber on that have a metal plate at the end to even end the bundle.  As long as your log is fairly square you can build a bundle like that.  Trim a layer or two at a time.  Use a jig or a guide to cut with a a saw like they use to cut beams.  10 wide will give you a 40" bundle if cut full.  15 layers high gives you a bundle of 150.  Build the bundle at the mill to reduce handling.
I know of guys that cut bundles with chain saws.  I don't think it is a good option with that tight of a tolerance.
rusticretreater
Logs are not straight so pre-cutting then ends wouldn't yield the results you expect IMO.  As you roll them to make the cant, it will end up off kilter.
The main problem with this is that without high(er) dollar equipment, you are stuck with 1. pretty much working from one side 2. repetitive motions 3. long pieces that require handling
The most difficult problem is getting the first end cut even so that you can cut the second end to length.  This is solved by cutting the cant itself before you make the 2x4's. Not optimal, but necessary.  The boards need to be stacked with all the finished end to one side.
My initial thoughts are a radial arm saw, a table and your tractor.  The table is the same height as the cutting surface of the radial arm saw. You screw/bolt/clamp a fence to the table and position it so that the blade is at the proper length for the cut when you put a board on it.
Depending on whether you are right handed or left, put the stack to be processed on your left side with the pre-cut end to the left end(right handed) or the right side with the pre-cut end to the left-end.  You place the boards on the table with the pre-cut end already towards the fence, get them squared up and cut as many boards at once as the radial saw can handle.  Then take the boards and stack them to the other side on your transport tractor.
So its turn left, get the boards; turn center, get the boards on the table; cut; turn right, stack the boards.  The opposite motions for a lefty.  Handling 2 boards at a time will cut the repetitions in half.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
blackhawk
I have seen chain beam cutters that go up to 18" cutting depth.
Lucas 7-23 with slabber. Nyle L53 kiln. Shopbot CNC 48x96
Bradm
Twin blade cutoff saw, one fixed saw and one adjustable, after milling the log.
A chainsaw setup on a pivot similar to a package saw with a fixed stop to set your length in a similar fashion to a firewood processor.
Mooseherder
A trim saw or board sizer like this one would probably work well.
This one is wider than the pic shows.
I had this exact same issue, but I never really got it solved satisfactorily. I tried cutting the logs precisely, but I still struggled to maintain that ½" variance. So I switched to a 42" chainsaw bar on a 390 Husky, and just trimming entire packs. I got that to work, but I still wasn't satisfied with the results. I did it by screwing upright 2x4s to the pack that I used as guides. I never added pads to the bar but that wouldve been the next step. This method would've worked well I think, if I would've went to the next step and built a steel jig that I could set the packs in, with squared steel uprights to run the saw guide pads on.
longtime lurker
I freakin' love jobs like this... its like everyone is panning for gold and I am too but I'm selling sand by the ton as well.
The accepted big answer is a double ended trim saw and it's well worth looking around the various used equipment brokers for a deal. You never know you might just get lucky.
The accepted medium answer is a pack docker. Material gets stacked in a frame with one end up tight, pack gets strapped and the entire pack goes through basically a glorified chainsaw on a fixed pivot point  to cut each end.
I still use a single saw with length stops. Thing being it's not the single saw that's the choke point it's the ergonomics around infeed and outfeed. To make it work with one person you need powered rollers and pop up or swing length stops so CTL is but a pause as the material goes down the line.
I dunno, I try and cut every log square in the yard but we get some awful ends in the mill. I'd not be expecting to find a solution out there.
scsmith42
Thanks all for the suggestions and ideas - lots for me to think over.  I really appreciate the sharing of knowledge; most of the equipment mentioned are things that I did not even know existed.
One of my fears is that if I invest a lot of $ into the "proper" production style equipment, if the buyer finds a better deal in a month or two I'll be stuck with an expensive boat anchor.  So phase 1 may be to see what I can fabricate on my own and in a few months if things are still progressing well then I can look at moving into phase 2 (double end trim saw, etc).
Rusticretreater - one thought that I had regarding pre-trimming the logs was to have the end trims be made perpendicular to two faces, and then to mark the faces so that I could set the log up on the mill and do full taper milling based upon those same two faces.  This might resolve "most" of the problem of the end alignment.  I have some leeway regarding the angle at the ends of the 2x4's, as long as the overall length is within spec.
I am familiar with the pack dockers (Holzer's).  One concern that I have is that if I'm purchasing logs that are the standard 16'6" - 17' lengths, if I'm careful with my trimming I would be able to net two 100" logs per 16'6" log.   But that does not give me much tolerance at all for any misalignments in the stacks if I'm using a pack docker.
Without question the suggestions regarding using RAS, double end trim saw or other saws with guides to cut through a dozen or so 2x4's at the same time on a conveyor would probably yield the closest tolerance results.   I'm just trying to figure out a way to reduce the labor involved in case the contact peters our in a few weeks / months.
Fortunately I have a well equipment welding and fabrication shop, as well as a machine shop, so if I can keep things simple enough I should be able to fabricate a solution in-house.
Please keep the ideas coming, and thanks again for the feedback.
Scott
longtime lurker
Ahhh, the real world where other people don't want me to spend all their money for them. ffcheesy
I've got a pretty serious gangsaw sitting in my shed - 80 hp main motor, belt feed, take a cant to 6" thick - that I never got installed. Pretty much got it home and lost that particular contract and it doesn't really suit my other work so there it sits waiting for either the right job to come along to justify installation costs or me to get motivated to advertise it for sale. I know where you're coming from about being prudent around one trick pony type equipment, however my experience suggests that on time and on spec delivery is at least as important as price point with this type of work.
I would go with upgrading the RAS you already have just because a good docking set-up  will have uses beyond one job. Length stops can be as simple as 4x2 blocks hinged to a set of rollers. 300 a week is only 60 a day, it's not that much unless you let it build up on you
Ljohnsaw
I think a pair of RAS' would be your best, cheap answer. RASs show up for free on CL all the time here. You could stand the 2x4s on edge and bunch up probably 8 to 10 at a time. With one RAS, trim first end, slide to stop and cut to length. Roller tables and flip up stops.
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
