Dynamic Green Products Inc.
Author Topic: Mitzifume in old utility poles  (Read 1105 times)
Offline mike_van
« on: July 16, 2005, 05:08:44 PM »
After reading   Larry's post about finding part of an Osmose drill bit in a pole, I  wanted to add another - Some of  our poles done by Osmose also have a really strong insecticide called  Mitzifume,  they drill a larger hole about 5/8", 2 per pole, and insert 2 Aluminum cigar size tubes containing Mitzifume, then plug the hole. The stuff is supposed to drain into the pole within a few weeks, but has to leave a high concentration in the treated area. We've sawn the old tubes off, thin Aluminum, but it's the dust & chips that can't do you any good - The poles are marked with a small  round badge with the name Mitzifume on it. The ones i've seen are near the ground, worst decay area. We've been told here [CL&P] that all old poles are SUPPOSED to come back to the yard, reason being haz-mat, they all have creosote, CCA or penta in them,  they get cut up 4' long & go in  a dumpster. Not supposed to give hazardous stuff away anymore.
Offline Kevin
Re: Mitzifume in old utility poles
« Reply #1 on: July 17, 2005, 12:27:34 AM »
Quote
It's the same here Mike.
Utility poles
Started by saltydog on Forestry and Logging
Last post June 19, 2015, 12:59:15 AM
by Dad2FourWI
Utility poles..
Started by talma on Sawmills and Milling
Last post October 13, 2019, 07:15:38 AM
by caveman
Laminated utility poles
Started by Tagerts_crossing on General Board
Last post February 07, 2005, 08:54:40 PM
by Fraxinus
Sawing utility power poles
Started by cypresskayaksllc on Sawmills and Milling
Last post September 30, 2011, 09:55:35 AM
by Chuck White
