We were logging today.
Started by Jeff, September 11, 2005, 09:12:48 PM
My wheels stick up a lot higher then that, but we easily got two rows of logs on. THe second row goes on easiest.
Frank_Pender
Not trying to tell the boss what to do or nothing, but your your design some recievers for some fender brackets to set in and then you have bolts to anchor them in tight.
 Then, whe you are loading logs remove the fender from the bracket recievers.
 for easy loading over the tires, install some secondary brackes of 2" tubing that is 1/3" wall, use these brackets for a loading framework somewhat like a beavertale on the end of a equipment trailer.  You could even install a roller or two to ease the loading over the tires.
Top of the telephone poles is over 10" off the deck.
Rec room looks good! ;)
They just sold one about that size yesterday, didn't catch what it went for but they built it on runners to be moveable.
Frank, I have the steel bought and in the back of my truck for doing just that. 8)
Here is a photo of the 2 by 10 floor joists we cut a week ago.
Furby, this one is 12 by 16 with the loft it takes up 16 by 16. Tammy plans a porch under the loft.  To big for going down the road, but we built this heavy to be moved around the property as we need to.
Yeah the one I saw was 12x20 plus the eaves.
Thought about it as we need one up at the lake, but decided I'll build one........someday. ::)
Actually wanted to make it log cabin style.
Are you going to match the house siding?
pigman
Jeff wrote "We are building a shed/poolhouse/guesthouse/doghouse."   I am now making my resevations for the next piggy roast. I want the guesthouse portion. I don't want to  run the dog out of his portion. ::) :D
sawguy21
I was wondering about that last part too. Hope the dog is on good terms with the guests. BTW. I love the smell of fresh cut pine but the pitch is a bear to get off :D
I would be the dog. Currently I have no place to escape to if needed. :)
Bro. Noble
Frank,
You better watch out telling the 'Big Guy' what to do :o-----------that's Tammy's job ;)
DonE911
I was considering setting up a trailer to winch logs up like that....    what size winch are you using?
Frank_Pender
Bro. Noble, ZI am sue to that sort of behavior , I do it around here all of the time.  I feel rather safe, as I have my whining room attatched the the main part of the house and do not even have to leave into the dark or dank weather. 8) 8) 8)
Quote from: DonE911 on September 12, 2005, 10:03:30 AM
Its a 1700 lb.  I got it a tractor supply. Here is a link
Seemed to have plenty of power. Even after winching on 9 logs the battery showed no signs of weakness.
DonE911
Thanks for the inff Jeff.
The farmer down the road has a 2000lb ATV winch still in the box he wants to sell cheap....  bought the winch before the ATV and never got the ATV...   it should work for me I guess.
Don, I would sure think so. Chet has a winch that I think is a tad smaller then mine and he manages to load some pretty big red oak with it.  I bet the one I saw on one of his loads was 30inch plus.  His fenders look good too. :)
timberjack240
jeff
you cood do like my pap did when he was a kid cuttin pulpwood load em by hand   :D just grab ahold of em and throw em on youll feel good till the end of the day  ;D  :D  ::) maybe
Well I do load logs like Jeff had by hand.
A chain and a strap, down and around and my body weight off the fender and it's done!
Have also done end for end (lift one end on and then try to lift the other) and I REALLY don't like that!!!
pigman
Quote from: Furby on September 12, 2005, 08:06:28 PM
The thing is Furby, most people do not have  the body weight that you have. ;) ;D
By hand?  THose larger logs are over 600 lbs.
ohsoloco
Were the logs all that sappy Jeff  ???  I like cutting red pine...white pine is one of my favorites, but it has a little more sap than the red from what I've milled.  Blue spruce in the other hand....  :-\
That's why I like Southern yellow Pine.  It's not sappy at all. ;D
Dan_Shade
Quote from: Jeff B on September 12, 2005, 08:44:59 PM
that's nothing, get to it!
lots of dull bands and chains
Green they are a little pitchy but It's what I would expect.
Don't tell me I need to drive up there and show you! ::)
I can see it being a problem with your shoulder though, so I'm not suggesting you try it! ;)
DonE911
OK.... got me a new winch ..  2000lb ATV winch for $50.   Well I will have it when I go get it... even comes with the correct mount for my ATV... just lucky on that part.
How do you have your winch mounted.  Looks like its mounted on the tongue and maybe a block on the other side of the fender you're smash'n.  Is it solid mounted or on some type of swivel?
