Author Topic: Black Walnut Trees For Sale  (Read 6599 times)
Stephannie
  • Guest
« on: April 19, 2001, 01:49:16 PM »
My husband Alan and I are new at this selling Black Walnut Trees,
We have total of 60 , and we are unsure on how to measure them and also
tell if they can be Veneer and also if they have knots and what grade they
are.
We just live in the country and there is not alot of people around here that
deal with this stuff.
This is what we need:
1. What grade are they?
2. They are still standing trees, we just want someone to cut them down and
take them.
3. Can they be Veneer? (what does that mean)
4. What's the difference between Butternut and Black Walnut Trees.
5. Who measures them?
6. What is Board per foot?
7. How do you calculate that?
8. What is #1 Common
          #2 Common
I don't understand those terms?
I appreciate it if you could help or know of someone in Minnesota or someone
anywhere that can look and make judgment on these trees.
Please get back to me ASAP.
Thank you,
Stephannie Langager
Offline Bill Johnson
  • Forest Tech
  • Location: Dobie. That's between Kirkland Lake and Quebec border
Re: Black Walnut Trees For Sale
« Reply #1 on: April 19, 2001, 02:59:07 PM »
Welcome to the forum Stephannie.
I am sure one of the guys will be able to either help you or at least point you in the right direction to find the answers you need.
From my perspective I can tell you.
1. Grade is usually determined once the tree is felled and the logs cut out of it.
2.Veneer logs are usually more valuable than either sawlogs or pulp but with the current markets I'm not sure if that is still the case.
Veneer is determined by log grade, the length of the log, the amount of defect in the log and the mean diameter of the log.
3.Butternut and Black Walnut belong to the same family so I would not expect there to be a lot of difference between the two species.
As I said earlier I'm sure Jeff and the others will be able to provide you will all the information you need. Good luck
Bill
Bill
Offline Ron Wenrich
« Reply #2 on: April 19, 2001, 03:33:03 PM »
First of all, you should have a consultant or a mill forester come out and look at your timber.  60 walnut trees should be enough to get someone interested to at least take a peek.
Veneer is the highest quality of timber.  Instead of sawing the log in a sawmill, it is sliced into thin strips.  Usually the trees are put in hot water to make them flexible.  This allows the knife to slice off pieces.  It is then glued into plywood, with other species as filler and the walnut as top wood.
To get an idea of what veneer looks like, go to Home Depot or Lowe's or your local lumber yard and look at plywood.  Veneer quality logs are needed to make plywood.
Veneer sized logs are 14" diameter at the end of an 8' log.  I believe walnut may be a little smaller, but not certain.  A tree that is about 17" dbh (diameter at breast height or 4 1/2' above the ground), will yield a veneer log at 8'.
For me, if I can get my arms around the tree and my fingers just touch, I have an 18" dbh tree.  If they can't touch, the tree is bigger.  If you have trees of this size, then someone will be interested.
Trees can be graded while standing.  It takes a lot of practice, knowledge of grading rules, and an eye for how defect will cut out.  The more defect in the first log, the lower the grade.  If the grade is known, lumber value can be projected.  Very few professionals do this, so landowners aren't expected to have much knowledge in it.
#1 common and #2 common are lumber grades.  It refers to the amount of clear lumber that is in a board.  The higher the amount, the more the value.  There is also a FAS and a F1F grade.  Again, landowners need not know this.
A board foot is a surface sq ft by 1" thick.  To find board footage in a board, simply multiply length (in feet) x width (in inches) x thickness (in inches), and divide by 12.
Finding the volume in a tree or log is a little different.  It is an estimate of the footage that will be cut from a log.  Diameter inside bark is used in logs as is the length.  For trees, use dbh outside bark, and the estimated number of 16' logs.
To get some figures, go to the homepage and you will find an area of calculators.  You will find one for finding log volume and another for finding tree volume.  There is also a section on cruising.  It might be fun to figure out how much volume is there.
Butternut is known as white walnut.  It is very similar to the sapwood in black walnut.  It never develops a dark brown heart.
When walnut is dried, they first inject steam into the kiln.  This will turn the sapwood brown.  The butternut, if included, will also turn brown.
Lastly, (whew), you may want to contact your local extension agent, or your state forestry office.  They should be able to direct you towards either consultants, loggers, or mills that would be interesed in looking at your woodlot.
Offline timberbeast
  • I Got nothin' to say :o)
    • Timber Buyers Network Contact Page
« Reply #3 on: April 21, 2001, 08:17:48 PM »
Stephannie:  If I were you,  I would definitely contact a licensed Forester to act as a go-between with you and the logger.  His job will be to ensure that you get a reputable guy,  and the most value for your timber.  He can also advise you as to the current market value,  and appraise your woodlot.
P.S.  I'll come and take them free,  if you just want to get rid of them!  Heh Heh!
Where the heck is my axe???
Offline RavioliKid
  • Gender: Female
  • If it's FREE, I'll take it; If it's CHEAP, I'll buy it; NEVER throw anything away!
« Reply #4 on: April 23, 2001, 04:00:45 AM »
Timberbeast, you are a helpful soul!
:D
RavioliKid
Black Walnut Trees For Sale   NEED HELP
Started by Stephannie on Ask The Forester
Last post April 23, 2001, 05:55:54 PM
by Ron Scott
Black Walnut nut meat for sale
Started by Greg on For Sale
Last post November 08, 2009, 07:09:53 PM
by SwampDonkey
Black Walnut Trees
Started by Cathy_M on Forestry and Logging
Last post September 17, 2004, 10:35:55 PM
by Kirk_Allen
Black Walnut Trees
Started by Deese on Sawmills and Milling
Last post August 31, 2013, 05:26:42 PM
by Fla._Deadheader
