Author Topic: Electric chainsaws  (Read 5091 times)
Offline Egon
Electric chainsaws
« on: October 08, 2005, 01:35:52 PM »
Can a good electric chainsaw do a proper job cutting firewood to length?
Thanks.
Egon
Offline jph
Re: Electric chainsaws
« Reply #1 on: October 08, 2005, 01:43:53 PM »
I have a small Hitachi ,use it mainly in the workshop. It works very well but I don't think I would want to  cut up too many logs with it.
John
Offline mike_van
« Reply #2 on: October 08, 2005, 02:09:37 PM »
I've got a Homelite, only 'cause I got it FREE at the dump - Its o.k. for the occasional cut in a building where you don't care about fit or finish, I wouldn't want to cut  my wood though, too slow.
Offline twoodward15
  • turnersville NJ
« Reply #3 on: October 08, 2005, 02:49:15 PM »
We like to call'em "sissy saws"!!!!
108 ARW   NKAWTG...N      Jersey Thunder
Offline Egon
« Reply #4 on: October 08, 2005, 09:00:44 PM »
Thanks fella's. :)
Guess I'll forgo looking at the Makita electric chainsaw and find some Quiche instead. :D
Egon 8)
Offline Bibbyman
    • Warden Sawmill
« Reply #5 on: October 08, 2005, 09:03:12 PM »
We use this Sears electric chainsaw around the mill. I think it's 4.5 amp with 16" bar.  Wouldn't be without one.  Thought about getting a second just so we could have one on one end of the sawshed and another on the other end.
I don't know if I'd take it as a first choice to cut fire wood but for lighter stuff, it'll work.  We'll butt off logs say 12" dia with it before we dig out the Stihl 044.
Sawing since '94
Offline lamar
« Reply #6 on: October 08, 2005, 10:19:57 PM »
I agree, I use mine for all kind of stuff. I also use it for small dia firewood that I bring in,then load it on saw buck.
Offline sawdust
    • Dream Dovetail Co.
« Reply #7 on: October 08, 2005, 11:54:11 PM »
Apparently Logosol makes a 220 version in Europe. As powerfull as a decent gas job.
David
comforting the afflicted and afflicting the comfortable.
Offline Egon
« Reply #8 on: October 09, 2005, 07:58:47 AM »
Again, a thanks to all. Just may reconsider the electric saw when finances are available. [ poverty 55 ]
Egon :)
Offline Bibbyman
    • Warden Sawmill
« Reply #9 on: October 09, 2005, 08:31:19 AM »
I saw a big electric chain saw used at a stave mill years ago.  I've not seen one since.
I think we gave like $70 for this Sears model so the cost is less than the throw-away gas models.
Sawing since '94
Offline Percy
  • Resident trouble maker
« Reply #10 on: October 09, 2005, 12:08:57 PM »
I have a 13 amp Husky at my millsite. Paid thru the nose but its a good unit. I use it for cutting flitches in half when Im makin long beams.  It can cut a 2 inch X 18 inch flitch faster than you can fire up and cut with a gas unit.  A very handy tool at the mill for cutting knotts,knotching when the log is "slightly " too large,emphasis on the "Slightly" heh..... ;D
Offline Frickman
  • Ouch, that hurt!
« Reply #11 on: October 09, 2005, 03:55:13 PM »
A griend of mine has a Stihl electric saw at his mill. It rests on a little shelf above the offbearer rolls. It's handy to pick up and trim the end off a board occasionally, but doesn't really have the power to cut alot of firewood.
Offline rebocardo
  • Atlanta GA
« Reply #12 on: October 09, 2005, 04:09:14 PM »
If you do buy an electric saw make sure it has a gear driven oiler.
Offline raycon
« Reply #13 on: October 09, 2005, 04:27:44 PM »
I cut blocking to length with a Prazi beam saw. Skilsaw with a chainsaw bar.  I'd not want to use it for firewood but works well on 8x8's.
Lot of stuff..
Offline JP
« Reply #14 on: October 09, 2005, 04:49:07 PM »
I bought a Sears (cheap) electric saw and put a logwizzard debarker on it/// lasted about 2 logs and ate the drive system//  JP
Norwood lm2000,Newholland 30 hp tractor, log carrier/winch, log arch  JP
Offline CHARLIE
  • Don't wait 'til both feet are in hot water before you decide to put your best foot forward.
    • Coulee Region Woodturners
« Reply #15 on: October 09, 2005, 09:50:28 PM »
I have an electric Poulan chainsaw I use inside my shop during the winter if I need to rough cut out a bowl blank for woodturning.
Charlie
« Reply #16 on: October 09, 2005, 10:15:01 PM »
There are one or two threads on the this forum somewhere that indicate that some safety equipment ment for chainsaws doesn't work good with electric chainsaws.   I'm specifically thinking of chaps.
Offline Egon
« Reply #17 on: October 10, 2005, 08:18:56 AM »
Again - Thank you very much for all the replies.
I have a Husky 365 with 18 and 24 in. bars but something lighter would be nice for small diameter firewood which mine will be.
Also thinking of taking it up a tree for limbing. Think the lighter weight and instant on/off would be helpfull. I'd use a generator when doing this.
Egon
Offline rebocardo
  • Atlanta GA
« Reply #18 on: October 10, 2005, 11:18:53 AM »
You do not want to take an electric saw up into a tree without GFCI protection. Not to mention dragging 50+ feet of 12 guage cord behind you will make the saw tough to handle and dangerous by itself.
I use a Husky 365 and MS-180. I use the MS-180 for firewood once in a while when I only have a little to do. The reality is, even though the Husky is heavier, it is better for firewood because it gets done much quicker.
The little MS-180 is much quicker then the 14 and 16" electrics I have and I think it probably weighes in close to the Remington with that huge motor. Plus, the electrics I have do not have anti-vib stuff, and the Husky has less vib. then the smaller MS-180!
From experience gained by repairing electrics from customers, one thing you have to take in account is that they have a plastic drive system which will completely shred if the chain gets jammed. So, I am not surprised one died quickly while using it to debark logs. When people are cutting limbs and catch the chain in a kerf, it is usually the end of the electric saw because they do not have a clutch system and the drive system is plastic. Plus, most I have seen do not have an anti-kickback brake (my Remington does).
Offline Dolmar_Tech_Mgr
« Reply #19 on: October 21, 2005, 10:41:41 PM »
The best Electric chain saw made is the Dolmar ES-171.  As far as electrics go this one is second to none.
Big electric Chainsaws
Started by buzzegray on Chainsaws
Last post June 17, 2010, 09:11:28 AM
by Ironwood
Electric chainsaws
Started by bandmiller2 on Chainsaws
Last post June 16, 2013, 07:21:25 AM
by bandmiller2
Electric chainsaws
Started by rick carpenter on Chainsaws
Last post March 01, 2017, 04:59:18 PM
by Gearbox
moved
MOVED: Electric chainsaws
Started by chet on Sawmills and Milling
Last post October 09, 2005, 09:56:39 PM
by chet
