BLUECREEPER Poster Award #4!
You can buy piston stops from your Husky or Stihl dealer for about $10. You want a metal one if you choose the screw in type and you can buy the long version and use it on all of your saws. The plastic screw in stops may break if loaded at an angle, they were originally made for the horizontal cylinder saws where the plug entered perpendicular to the crown of the piston.A cheap and workable substitute is enough clean starter(or lint free, minimally compressible) rope fed through the plug hole to lock the piston, then it`s a left hand thread to remove the clutch. Be careful that you don`t allow the rope to go into your exhaust port as you feed it into the cylinder.Russ
... I have had very good luck with the Oregon 95VP Micro-lite chain. Real agressive but thinner kerf seems to keep the small saw from bogging down with a longer bar. Remember if you use this chain you have to get a Micro-lite bar to go with it.max
Started by Coot on Chainsaws
Started by fivedogs on Chainsaws
Started by tharreld on Chainsaws
Started by bandmiller2 on Chainsaws
