Dynamic Green Products Inc.
Author Topic: BLOWER PROBLEM  (Read 1226 times)
Offline GAV64
  • I hate the daily routine!
BLOWER PROBLEM
« on: November 05, 2005, 07:47:52 PM »
well not a chainsaw but a 2 stroke problem and I think you folks can help me. I have a dolmar back pack blower it runs fine for about 5 miinutes then slowly loses power and stalls, about 7 years old and has alway run flawlessly, any ideas. thanks ahead of time glenn...
Offline kenskip1
  • Stihl Looking for the fountain of middle age.
Re: BLOWER PROBLEM
« Reply #1 on: November 05, 2005, 09:04:28 PM »
Change the gas filter. Possibly a gas tank vent issue
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
Offline ladylake
Re: BLOWER PROBLEM
« Reply #2 on: November 06, 2005, 06:31:13 AM »
Glen  As ken said vent or fuel filter, to check the vent , after it stops loosen the cap and listen for air going in the tank. Tighten the cap again and try starting it. If it runs good for 5 minutes again you have a clogged vent. I don't think it would run 5 min with a clogged filter. but wouldn't hurt to check it.  It could also be a bad coil, check how good the spark is after it dies. Check fuel lines for cracks also.  Good luck.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline kenskip1
Re: BLOWER PROBLEM
« Reply #3 on: November 06, 2005, 03:28:59 PM »
I have been doing some thinking and here is what I have come up with about this anomoly. The rings are more than likely worn. As the saw is cool, you have enough compression to get it running. As the engine heats up and the worn rings loose compression, ther-by causing your problem. Can you get a compression tester?This will tell me if I am wrong or not. However 7 years for a blower  IMHO is pushing it. God luck, Ken
Stihl The One
Stihl Going Strong
I have a problem problem starting Stihl ms290 chainsaw
Started by bardos on Chainsaws
Last post May 07, 2015, 08:42:26 AM
by GAB
3-53 Bad blower?
Started by nblogger on Forestry and Logging
Last post November 05, 2012, 06:17:16 AM
by nblogger
Chip Blower
Started by Max sawdust on Wanted
Last post August 10, 2006, 08:01:43 AM
by Max sawdust
Sawdust Blower
Started by learydeere on Sawmills and Milling
Last post November 25, 2012, 08:21:17 PM
by samandothers
