Author Topic: Manual log turner on Woodmizer  (Read 4323 times)
Offline sawyerkirk
  • Give me a lever big enough and I'll move the world
« on: September 10, 2002, 08:48:10 AM »
I'm sawing on some huge pecan logs, when the biggest log just won't turn on my mill, after quite a few cuss words, some fretting and fuming (it was 96 degrees so  I was allowed) I looked at the teeth on my log turner, they were at least 3/4"shorter than when they were new, the top tooth is still pretty decent, but the middle two are flat. It's just one of those things I never thought to check on maintenance day. So, I pulled them on and going to try to regrind the points. Those teeth have moved alot of wood.
Re: Manual log turner on Woodmizer
« Reply #1 on: September 10, 2002, 11:17:08 AM »
I guess they have.  I went out and looked at mine after reading your note and I can't tell the difference.  They aren't as sharp but they are still as big.  Maybe because I cut pine and cypress, Huh?
Offline sawyerkirk
« Reply #2 on: September 10, 2002, 11:44:22 AM »
99.9% of the logs those teeth have turned were Oak, Pecan or other hardwood. and all very large!!
Offline Bibbyman
    • Warden Sawmill
« Reply #3 on: September 10, 2002, 11:51:07 AM »
I wonder if Wood-Mizer made the log turner claws of softer material at one time.  I talked to one WM owner who said he'd replaced the claw plates on his turner. ???
I did retrofit our old manual LT40 with a turner and over two years, didn't notice any wear past paint removal and polishing.  The new Super has a double set of claw plates.  ;D
Sawing since '94
Offline OneWithWood
  • I am happy!
« Reply #4 on: September 10, 2002, 11:54:00 AM »
mmm...please define very large   are we talking 36" or 30" or 26" at the big end?
One With Wood
« Reply #5 on: September 10, 2002, 11:56:30 AM »
I define "very large" as a log that DonT want to do what I want it to do. DanG, I hate a smart log !!!!
Offline sawyerkirk
« Reply #6 on: September 10, 2002, 05:42:29 PM »
My version of large is 30"+ on the width and 16'+ on the length. Rarely do I ever get a log that is 30" but only 8' long or a 16' log that is only 18" or 20" across.
Offline OneWithWood
  • I am happy!
« Reply #7 on: September 12, 2002, 12:30:07 PM »
Yep, 30" x 16ft is a large log in my book, but then my book is kinda small :D
What would be the average size of logs you mill?
One With Wood
Offline sawyerkirk
« Reply #8 on: September 12, 2002, 01:13:17 PM »
The average log I bring home is 16"x12' we cut alot of oak, gum and cottonwood into wedges and stakes,(about 5000bf/week) so I don't bring home logs anywhere near 16'x30". I don't like to use the turner, so I use the cant hook as much as possible. Invariably though 1/2 the custom jobs we do end up being some huge unrulely log like a 16'x30" pin oak  or a pecan that is 4' across and 4' long!! or a "square"(ever seen a square log?) hard maple 46"x46" on the big end and 14' long with a huge rotten whole in 1/2 the side. customer says "can't you get some good lumber off that spot isn't rotten?" (it's still laying there) I can continue with big ugly log stories if you'd like!!
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #9 on: September 13, 2002, 06:01:26 AM »
   My hydralic turner turns about 50% hard woods and after 1/4 million bdft  the paint is worn off.  I have turn some big ones with it and it turns 24" 32 ft logs  with no problem and I have sawn logs up to 42"x 12' on the mill.  Maybe you just got a bad set of teeth.  If you are sawing that much a week maybe you need to upgrade to a hydralic mill.
 ARKANSAWYER
ARKANSAWYER
Offline sawyerkirk
« Reply #10 on: September 13, 2002, 09:35:14 AM »
One of these days...one of these days...most of what we cut is into 6/4 or 4x's, so it's not quite like cutting 5000bf of 4/4 stock. I know when I ground them down, they were pretty soft. It may be just a mystery never revealed.
Using the Manual Log Turner Woodmizer LT40
Started by richhiway on Sawmills and Milling
Last post May 09, 2019, 08:47:17 AM
by Resonator
manual log turner
Started by woodweasel on Sawmills and Milling
Last post March 18, 2017, 06:34:28 PM
by Brucer
lt30 manual turner
Started by trapper on Sawmills and Milling
Last post April 04, 2013, 01:29:40 PM
by Andries
Video of WM manual toe board and turner??
Started by Brad_bb on Sawmills and Milling
Last post February 12, 2017, 08:05:14 PM
by Darrel
