Dynamic Green Products Inc.
Author Topic: re: sprocket bearings  (Read 1311 times)
Offline foresthawk
« on: November 09, 2005, 07:40:45 PM »
 I am working on an old  Craftsman chainsaw, and am in need of  a sprocket bearing. (old one is disintegrated).  I have checked and cannot get them through Sears parts (although I can get the sprocket.)
My question:  Where can sprocket bearings be obtained for this (and any other older saws?  - I have others as well.)
 Thank you for any feedback.
Offline Kevin
Re: re: sprocket bearings
« Reply #1 on: November 09, 2005, 09:11:35 PM »
Is that for a 7/16 shaft?
Offline Chris J
  • I'm new! Well, not exactly "new."
« Reply #2 on: November 10, 2005, 01:24:08 PM »
FH, I might be able to help, do you have the sprocket part #?  Most of what I have are spur sprockets.
Certified Amateur Chainsaw Tinkerer.  If sucess is built on failure, then one day I'll live on the top of Mt. Everest.
Offline foresthawk
« Reply #3 on: November 10, 2005, 08:55:34 PM »
 The Sears part no.  is  9089H , listed as a  "needle bearing."
 It is actually the sprocket bearing -  the bearing on the shaft the clutch and sprocket ride on.
   the shaft diameter is  7/16 inch.
  The chainsaw model no. is    917.353750
Offline Kevin
« Reply #4 on: November 10, 2005, 09:01:51 PM »
Oregon(Blount) should have them, write their tech staff and ask them, it's probably a Poulan saw.
Ask about this part number 28006, sprocket and bearing.
Sealed bearings or greasable bearings on blade guides
Started by fathead on Sawmills and Milling
Last post October 31, 2012, 08:22:34 AM
by Cypressstump
hot bearings
Started by millstead on Sawmills and Milling
Last post February 01, 2013, 10:29:02 AM
by thecfarm
bearings
Started by kev on Sawmills and Milling
Last post May 08, 2009, 07:23:49 PM
by ARKANSAWYER
10-10 bearings
Started by MickMac on Chainsaws
Last post October 16, 2017, 03:20:43 PM
by MickMac
